07-07-2018, 10:04 AM | #1 |
lincoln transmission
i have a lincoln transmission what should the teeth count be if it,s a zephyr cluster gear input shaft second gear.
07-07-2018, 10:50 AM | #2 |
Re: lincoln transmission
Depends on the year, the early ones had the same gears as a ford
07-07-2018, 10:53 AM | #3 |
The tooth count on the input will be either 18T or 19T if it's a LZ transmission.
Good Luck Paul J. |
07-07-2018, 10:57 AM | #4 |
