07-31-2022, 01:41 AM | #1 |
off topic
I am currently working on rebuilding a 1907 Humber engine. This thing is a four cylinder Tee head arrangement [a non removeable head], with each cylinder assembly being individually bolted onto a two piece aluminum crankcase. Pistons [cast iron] are stuck inside three of the [cast iron] cylinders. I've managed to remove the last one. I've been soaking each cylinder assembly in penetrating oil, but have had no success [yet!] in freeing these pistons up. So, with this cylinder arrangement, I am unable to get to the top of the pistons to hit them downwards and out the bottom of the cylinders. And hitting the conrod in order to move the piston upwards to hopefully free it is not working [it did work on the one]. Can any of you guys offer advice as to any other steps I can take to facilitate piston removal? Thanks.
07-31-2022, 02:41 AM | #2 |
Re: off topic
If it is a four stroke engine with the valves closed make an adapter to screw in the spark plug hole with a grease fitting in it and hydraulic it out with grease or oil or both.
A lever action grease gun will develop a lot of pressure. Once you get the pressure on it heating the cylinder will help. Bill |
07-31-2022, 02:56 AM | #3 |
Re: off topic
Careful using hydraulics as Bill suggested. A great idea but hydraulic force can destroy almost anything. Brian I would suggest soaking with a mixture of brake fluid and mineral spirits or diesel. Give it a week keep adding above then set it on fire. May need to add some rags. I won’t be hot enough to damage but the different expansion rates hopefully will help you get it apart. Patience my son! May take a couple of tries. Good luck.
07-31-2022, 03:43 AM | #4 |
Re: off topic
In a coupla weeks I'm gonna hot these things up! Cheers.
