02-02-2015, 04:35 PM | #1 |
Tighten Rear Axle Nut
I drilled a 5/8" hole in my brake adjusting board to keep the hub from spinning when I tightened the axle nut.
02-02-2015, 05:21 PM | #2 |
Re: Tighten Rear Axle Nut
Thats a good idea especially since I'm one that uses an adjustment board.
02-02-2015, 05:25 PM | #3 |
Hey Bruce,
GOOD idea ! Now what torque value do you use for this nut ? |
02-02-2015, 09:07 PM | #4 |
Torque value tighten nut until wood snaps :-)
02-02-2015, 11:50 PM | #5 |
I thought it was "all you could get on the wrench and one more round .." That was a saying often made as a joke in a Model A club that I used to know a few members. I remember a story told to me about a newbie restorer in that club who took that joke literally. He tightened the axle nut as tight as he could get it with a big wrench, marked the position, and then proceeded to strike the wrench handle with a sledge hammer until the nut rotated "one more round .." ... and stripped the threads !!! (LOL) |
02-03-2015, 12:02 AM | #6 |
I start at 125 foot pounds, back off 10 or add 10 to align key. A's Always Dave |
02-03-2015, 06:53 AM | #7 |
Great idea; thanks.
I imagine you could put that board on the other side of the drum to use it for loosening/removing the axle nut, correct? |
02-03-2015, 08:14 AM | #8 |
02-03-2015, 08:25 AM | #9 | |
I see torque of 125 in other post. I only went to 100, hope that was Enough , I drove last year like that. Fredski |
02-03-2015, 08:58 AM | #10 |
Why does it have to be in gear
02-03-2015, 09:52 AM | #11 |
it doesn't
'31 180A |
02-03-2015, 01:55 PM | #12 |
I've tightened as much as 125# once . If there is any question about the over 80 year old threads, I stop at 75 # . I've never had a problem with the axle nut at 75 #
02-03-2015, 01:59 PM | #13 | |
I go 75 -100 2-3 burbs of my 1/2 impact Last edited by Mitch//pa; 02-03-2015 at 02:16 PM. |
02-03-2015, 05:39 PM | #14 |
[QUOTE=Mitch//pa;1027084]Why does it have to be in gear
Just thought if the opisite back wheel was on the ground , in Neutral the trans would not lock up,and wheel would still turn. I'm possibly wrong here. Fred |
02-03-2015, 06:40 PM | #15 | |
[QUOTE=fredski;1027321]
It seems to me that the adjustment board is being used to hold the hub from turning. |
02-03-2015, 08:27 PM | #16 |
I get it as tight as I can with my 24" breaker bar. I had an axle break once, probably because the nut wasn't tight enough and let the drum work back and forth for many miles.
02-05-2015, 04:52 AM | #17 |
02-05-2015, 07:58 AM | #18 |
[QUOTE=Bruce of MN;1028180]Correct, It would work if the banjo was empty.
02-05-2015, 04:40 PM | #19 |
I was responding to post #9.
