Old 05-21-2019, 11:04 PM   #21
SSsssteamer
SSsssteamer's Avatar
Default Re: What modern points do you use?
With the 1957 to '74 points, the modern condensers are crap. Make sure that you carry an extra condenser under your seat for that roadside emergency. NOS modern condensers should be better condensers if they have been properly stored. My first modern condenser lasted me about 35 miles before it crapped out. I have put several thousand miles on since then and it has been reliable. My modern points are still spot on for adjustment.
SSsssteamer is offline   Reply With Quote
Old 05-21-2019, 11:36 PM   #22
RandyinUtah
I have been running so called modern points for the last 15 years and can't remember the last time I had to change them. No up keep except cam lube.
RandyinUtah is offline   Reply With Quote
Old 05-22-2019, 07:21 AM   #23
leo
leo's Avatar
Hi RandyinUtah, I'm fairly certain anyone could say the same for conventional points too.
leo is offline   Reply With Quote
Old 05-22-2019, 08:46 AM   #24
CWPASADENA
CWPASADENA's Avatar
I have modern in one car and original in the other.
Both have performed very well BUT the modern is so difficult to adjust. I would not use any more modern points because of this.
There are now very good quality distributor parts available for using original points. The repo upper plates have to be reworked a bit to get the point block aligned correctly.
Good quality modern and original points are available from O Relly's
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-22-2019, 09:32 AM   #25
katy
katy's Avatar
Originally Posted by Werner View Post
My nice Little Green Roadster had mounted the modern plate and points when buying.
I wanted to equip to original and ordered the early base plate and the original replica contact points and the capacitor. Remodeled, and as I wanted to set the contact points with the maggot screw, I saw that the angle of the points was not parallel, they only touched on one outer edge. That's bad and that's why I had to put back on the modern base plate angrily. Was 'Made in USA'.
I also had that mis-alignment problem, filed the mounting holes for stationary point block so it could be adjusted to line up.
Old 05-22-2019, 09:42 AM   #26
Purdy Swoft
Purdy Swoft's Avatar
I've also used a file in the holes that the points block attaches to ...
Old 05-22-2019, 10:28 AM   #27
The Master Cylinder
The Master Cylinder's Avatar
Just curious, has anyone installed a Pertronix Ignitor ii or Ignitor iii on the modern upper plate? I know FSI uses the Ignitor but I believe it is the Ignitor i.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-22-2019, 11:24 AM   #28
30 Closed Cab PU
Brattons sells a modified point block that corrects this issue. New original style points
arm is too long. Brattons are the only vendor to offer this point block. I recently converted back to original design parts, had issues with the nurex wireless plates. The original parts with this point block has been working perfectly.
https://www.brattons.com/machined-di...int-block.html
Old 05-22-2019, 11:57 AM   #29
burner31
burner31's Avatar
Update to the update:
Now I'm not getting any power to the points...moral of the story...if it works, leave well enough alone.
Keith
Shawnee OK
'31 SW 160-B
Old 05-22-2019, 11:09 PM   #30
katy
katy's Avatar
Live and learn,
Old 05-22-2019, 11:40 PM   #31
Ruth
See post #20
Old 05-23-2019, 12:19 AM   #32
Pete
Pete's Avatar
With a properly modified base plate and Ford 6 points from the 60's, the distributor will fire reliably to 6000 rpm for several years. They will be easy to adjust also.
THE CONDENSOR USED MUST MATCH THE COIL OR THE WHOLE SYSTEM WILL FAIL.
It is exactly the same as the tuner in a radio or TV, the system must be tuned to resonance to function properly.
Old 05-23-2019, 11:16 AM   #33
California Travieso
Send a message via Yahoo to California Travieso
Pete,
You said "With a properly modified base plate . . ." Do you mean a modified "original" plate or a modified "modern" plate?
David Serrano
California Travieso is offline   Reply With Quote
Old 05-23-2019, 12:07 PM   #34
Pete
Pete's Avatar
Originally Posted by California Travieso View Post
Pete,
David Serrano
It can be done either way.
Old 05-23-2019, 02:10 PM   #35
Ruth
Why would the 6 cylinder points be any better that the V-8 points of the same era, which is what they used to the "Modern Upper Plates"?
Old 05-23-2019, 02:23 PM   #36
Pete
Pete's Avatar
Ask Joe Panek at Roto-Faze.
On second thought maybe we better not bother him.
His distributors were on winning cars at Indy several times.
Maybe the 6 cylinder ones were on sale the day he designed it.
Old 05-24-2019, 10:10 AM   #37
katy
katy's Avatar
One thing to note, the 6 cylinder distributor turns clockwise and the V8 distributor turns counter clockwise, so the respective point sets are opposites.
