05-23-2012, 09:09 PM | #1 |
distributor / coil rebuild on 36
sent dist/coil to a well known ignition expert from this site. came back w/out coil done. sent same to Skip to do coil check work on dist. Skip said the freshly done dist 'was all screwed up'. Im out $100 to the ignition expert.
05-24-2012, 05:53 AM | #2 |
Re: distributor / coil rebuild on 36
And what was wrong with the distributor? I would for sure want to know just in case that was one we did??? We do quite a few of the helmets with no problems what so ever.
However we dont do ignition coils. Every unit we touch is ran on a tester for some time , adjusted with a load on it and tested again before going to the customer... |
05-24-2012, 06:02 AM | #3 |
Yeah, that's kinda messed up to just post "i sent it out and I'm out $100". No mention of whether he tried to work with the 'ignition expert' or what was wrong with the distributor. Complaints like this are of no value to anyone if they don't give specific info on what's wrong, what was done to attempt to correct it, and what the communication was between customer and vendor. If you are trying to be a gentleman and protect the reputation of the vendor, the information about the transaction can still be posted without revealing any names.
Anybody can make a mistake but you have to give the person notice and give them the opportunity to make it right or refund the money. Even the People's Court allows for that basic courtesy. Dont' know if this was done?
36 1/2 ton pickup on 38 car frame with 1940 v8 24 stud |
05-24-2012, 07:21 AM | #4 | |
05-24-2012, 07:36 AM | #5 |
I agree with you and I applaud you for not mentioning any names until you find out more information. Its the right thing to do. My point was if you don't know what is messed up and you haven't talked to the ignition guy, then you are a bit premature to say you're out $100. Maybe the guy screwed it up royally and won't stand behind his work. Maybe he will apologize and return your money. Maybe Skip will come back and say its not as bad as he thought and its really okay. We just don't know yet. It's like "READY!..FIRE!...AIM!"
05-24-2012, 07:52 AM | #6 |
www.fordcollector.com |
05-24-2012, 08:09 AM | #7 | |
i |
05-24-2012, 08:16 AM | #8 |
In my opinion all of the ignition rebuilders who post here are good reliable folks who do excellent work. Making a post like this that makes others wonder who MAY have done a poor job is not the best thing to do unless all possibilities for privately resolving this issue have already been pursued and failed to bring final resolution. JMO
05-24-2012, 08:33 AM | #9 |
John I agree with you and would not have responded except for the fact that the problem was posted along with the names of the people involved. Since I KNOW and SAW the problem and results rather then second handed information I reported the facts as they were. I will say one thing I liked the rebuild tag that was on it so there is no doubt where it was rebuilt. G.M.
05-24-2012, 09:15 AM | #10 | |
I guess at this point we can assume you have called the "expert" and discussed the problem ? If not you are totally wrong in this entire post !!! |
05-24-2012, 09:22 AM | #11 |
The only name I mentioned was Skip and that was in a positive way. Yes, that is a nice decal.
i |
05-24-2012, 09:34 AM | #12 |
05-24-2012, 09:38 AM | #13 |
I have to agree with Scott H on this one. If there is a problem with a vendor no matter who it is, contact and communicate with the vendor about the problem. Please don't come on here and give a vauge post about it. All of the well known vendors on here are good people and are willing to work out the problems. They have to be because of the niche market we are involved in. JCWEEZER I suggest you give the original rebuilder a call and work it out, if you already haven't. Don't loose your cool and give the person a chance to make it right, that's only fair.
05-24-2012, 09:51 AM | #14 | |
05-24-2012, 10:43 AM | #15 |
OK, i want to solve the puzzle ! ( been watching jeopardy)
The distributor has got to be one of mine and i do remember the customer, ( he was that special ), he was upset that i refered him to Skip ( i do send Skip a lot of business as i respect his work) for the coil as i dont do coils and that coil isnt available. We as usual cleaned and built the distributor , polished the advance weights and sprayed a dry lube on all the parts to prevent rusting. The end clearance was checked and i ran it on my tester for some times just like i always do. The points were adjusted using the 1936 Ford bullitins , ran some more and then retested. I do each and every one of these myself before shipping. We also isolate the rotor shaft with shrink wrap to prevent internal arching. And for all this we charged a whopping $48 plus parts and shipping.. On the vacuum issue we just leave them loose for the customer to adjust on the car after start up. We preset the screw three turns in and leave it that way as i have no clue how much vac each flathead has . The piston has new leather rinstalled and is lubed with marvel mystery oil. JCWEEZER hasnt called us with any concerns or ever mentioned any problems whatso ever before this to me or any one of my staff. Every now and then in business you just need to fire a customer and this is one of those times i guess. JC please call my office using our toll free 1-888-809-3835 number and give her your invoice number and she will issue a refund check right away of the labor and shipping . I will not refund for the parts as i have to believe that Skip found them to be the best money can buy and left them in the distributor! Signed , a very unhappy "Bubba"..... |
05-24-2012, 11:23 AM | #16 |
"Every now and then in business you just need to fire a customer and this is one of those times i guess."
Agreed, you can't please everyone no matter how hard you try. My hat's off to Bubba for his proper handling of the situation. |
05-24-2012, 12:30 PM | #17 |
And just for some closure a check just went out today as a refund to JCWEEZER also known as Jerry Weiser.
He finally did call for his refund... |
05-24-2012, 12:30 PM | #18 | |
Bubba, I'll post when I get the check. I'll consider myself fired. i |
05-24-2012, 04:28 PM | #19 |
JCWEEZER I consider you FIRED Also !!
05-25-2012, 08:55 PM | #20 |
Now he thinks he isnt going to get the check.....geez. You're Fired!!!
"Street rods have a Chevy in front and a can of wax in the back.......Hot Rods have a Flathead in front and a box of tools in the back"-- Fred Offenhauser Check out my blog on my Flathead project! http://myav8.blogspot.com/ |
