Old 05-31-2012, 10:09 AM   #1
Slick Steve
Default 1939 Tudor 8BA & T5 questions
I have. '39 Tudor with a Flathead. I am wanting to putmin a t-5 5 speed. Has anyone done this? I have done a search and found nothing. What is needed? My main concern is how it ill fit/mount in the frame.
Thanks for the help!
"Street rods have a Chevy in front and a can of wax in the back.......Hot Rods have a Flathead in front and a box of tools in the back"-- Fred Offenhauser
Check out my blog on my Flathead project!
http://myav8.blogspot.com/
Slick Steve is offline   Reply With Quote
Old 05-31-2012, 10:49 AM   #2
38 Hump
Default Re: 1939 Tudor 8BA & T5 questions
I posted a reply on the HAMB!
38 Hump is offline   Reply With Quote
Old 05-31-2012, 12:31 PM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
38 HUMP REPLY IS HERE :
http://www.jalopyjournal.com/forum/s...d.php?t=703183
i WAS CURIOUS MYSELF....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 06-01-2012, 09:44 AM   #4
wyonorm
Should work fine if you convert to an open drive line. Some time ago Flat Ernie was working on a t5 to closed drive line adaptor. I don't know if he finished that or not.
wyonorm is offline   Reply With Quote
Old 06-01-2012, 10:11 AM   #5
Ford Flathead
I have one. you have to split the wish bone, make a new trans mount. I sell the adapter kit. H&H Flatheads. And change to open drive shaft.
Ford Flathead is offline   Reply With Quote
Old 06-01-2012, 10:31 AM   #6
professorpat
Steve, I would suggest to convert to a hydoralic (sp) throw bearing, and a t-5 from a chevy S-10. This will save a lot of problems, and move the shifter to the correct spot. We used a ford ranger rear end, it was the correct width for my 37. Good luck
pat
professorpat is offline   Reply With Quote
Old 06-01-2012, 04:54 PM   #7
cuzncletus
cuzncletus's Avatar
I did this conversion in my 39 Tudor. the center X member brace has to be replaced and the wishbones split. I used Chassis Engineering's kit. If the body is not off you will have to cut the floor. Go to www.5speed.com. They will tell you everything about the non-world and world class T-5's. The adapter I used was bought from a guy right here on Ford Barn, Krylon32. I forget which is his rod shop but his kit was vastly more simple than one I ended up returning to Honest Charlie's. He's a good guy to do business with. The above post is right; use one out of an S-10 for correct shifter positioning. Some complain about the low first gear ratio in my trans but it works fine for me with a 3.70 rear out of a Granada. I paid $100 apiece for two and have one set back for a future flathead project. I've test driven the car only so far but it seems to work well and I don't foresee any bugs coming like I do with some other systems on the car. The 8ba may give you some problems with the drag link under the pan. I used a new Saginaw steering box and the clearances between the drag link and pan seem awfully tight. I think if I did it over again I'd go with the stock box. You may also have some header fit problems. Again, a stock box may have alleviated this.
cuzncletus is offline   Reply With Quote
Old 06-02-2012, 12:11 PM   #8
Flat Ernie
Flat Ernie's Avatar
Nope, never finished. All my car stuff is on back burner - life keeps getting in the way.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 06-02-2012, 08:37 PM   #9
felix37
felix37's Avatar
I used Chassis engineering,split kit with the t-5 adapter kit from Speedway. You can remove the center x member from underneath the car and with out cutting up the floor pan! I had no problems with mine! just takes a little time and patience to grind out the rivets. This is by far one of the best modifications one can make to an early Ford!
Well worth the effort!
felix37 is offline   Reply With Quote
