01-04-2012, 01:57 PM | #1 |
early '28 AR body/frame
My Phaeton driver side floor railing has an oval shape hole for the early E-brake handle, was this normal for all '28 cars or are there records of when this was eliminated ??
I can post a pic later thanks! |
01-04-2012, 02:07 PM | #2 |
Re: early '28 AR body/frame
My August 28 Special Coupe also has it with a cover over the hole.. I have seen still later 28 cars with it.
01-04-2012, 06:04 PM | #3 |
My October 12th 1928 60-A Leatherback Fordor has the hole and still has the earlier 3 piece service brake assembly.
01-04-2012, 07:35 PM | #4 |
this is what I'm talking about, is this hole on all 1928 Models ????
01-04-2012, 08:15 PM | #5 | |
You can key out your body with the NEW MARC/MAFCA Restoration Guidelines and Judging Standards! Pluck Last edited by Steve Plucker; 01-04-2012 at 09:14 PM. |
01-04-2012, 08:25 PM | #6 |
Talking about the left hand e-brake hole, I have 2 with the right hand holes that also has the left hand holes. Also the wood that fits in that section HAD to be different, to clear the handle. Dudley |
01-04-2012, 08:39 PM | #7 |
My 6/1/28 tudor has that hole. It had a sheetmetal cover fastened with screws, I suppose to keep water and dirt from getting in.
01-04-2012, 09:05 PM | #8 |
My 12-8-28 76-A pickup does not have the hole and plate.
01-04-2012, 10:33 PM | #9 |
Fred and Glenn, can you guys post photos of the cover plate ????? THANKS!!!
01-04-2012, 10:58 PM | #10 |
Here is the plate on my 9-27-28 Phaeton. Notice that at least one of the two plate screws appears to be the wrong one. That should not be a flat head screw on the lower one. |
01-05-2012, 09:54 AM | #11 |
Speaking of emergency brake holes, how many of you have a vehicle that has the tab on the outside of the hole? This was not a common feature on the early A's but it was not that uncommon either. This particular photo is a barn find photo of the body for A217.
