05-08-2020, 04:45 PM | #1 |
elect problem
why is the voltage regular in my 1950 f1 getting so hot ? lights and all work ok ...
05-09-2020, 06:39 AM | #2 |
Re: elect problem
"So hot" is meaningless, how hot is it actually getting?
05-09-2020, 06:42 AM | #3 |
Re: elect problem
There are a couple of large resistors mounted under the regulator that can generate heat. Make sure some air can get to the resistors, so the heat does not build up.
05-09-2020, 10:02 AM | #4 |
Re: elect problem
Make sure you don't have a short somewhere.
05-09-2020, 11:29 AM | #5 |
Re: elect problem
yes they run hot until the voltage is satisfied all ceramic resistors run hot under load
05-10-2020, 08:04 AM | #6 |
Re: elect problem
