10-05-2019, 01:05 PM | #41 |
Re: Replace Flathead with Y-Block?
Believe it or not, Ford actually made an adapter to do this for trucks. They also made a kit to convert from the flat-6's to the OHV 6's. The parts lists for the kits runs to 2 pages...
Never seen one of these adapters myself.
'52 F-1, EAB flathead |
10-05-2019, 01:10 PM | #42 | |
We did have a 54 F600 that was.converted from a 6 wheeler to a 10 wheeler full screw |
10-05-2019, 01:41 PM | #43 |
The 312 wasn't any better. It was the worst of the bunch. The 292 was lousy but probably the best Y block. The 57 312 introduced the Holley spread bore carburetor which was a milestone but a terrible overall engine. The engine code was ECZ. I know, I had several back in the day.
10-05-2019, 04:28 PM | #44 |
In the late 50's I built a 345ci "Y" block for the drags for a fellow. The engine had a C&T stroker assy with floating bearings. The roda were bored out to except them. Yes it was a welded crank. Clay smith hard faced cam and Hilbore Fuel injectors. I'd never run anything like this before and my stupid factor was very hi. Took awhile to get the tuning figgered out. The flame thrower ign gave us problems as the rotors would short out. solved this with stock coils. Engine was bolted uo to a cad.LaSal trand and 4.10 rear, Altho we never got it to a drag strip. It's the only vehicle I ever drove that could spin the tires while cruising at 60 mPH. The acceleration was more thar the Hemi 66 Dodge I ran
Yes if you put the time and money into one, they wii run |
10-05-2019, 04:30 PM | #45 | |
As well, I have in my growing years committed conversions that just ate up time energy, and cash I regretted later. Good Luck I understand the aspect of having that look when the hood goes up. (seldom mentioned fact: Ed 'Big Daddy' Roth had a '55 Chevy with a 406 just for fun)
Enjoy yer day. Tom Hate can't fix what it started. |
10-05-2019, 07:57 PM | #46 |
10-05-2019, 08:03 PM | #47 |
Most adapters for these transmissions show them fitting '49-'64. "rotorwrench" has posted some good information on the previous page.
10-05-2019, 11:33 PM | #48 |
looks like a pretty complete kit. It even includes the engine!
10-07-2019, 01:11 PM | #49 | |
A Ford Y block beat out two small block Chevys a Pontiac and a Studebaker V8 at last weeks Engine Masters Competition. It finished behind a 390 and 289 Ford and a couple big block Chevys with the latter two only beating it by a little. Remember this year the engines were required to run factory block and head castings. Ford Y blocks have won this competition twice. No early Olds, Caddy, Buick or small block Chevy has accomplished that feat yet. |
10-07-2019, 02:11 PM | #50 |
I always liked "Y"-blocks, especially the intake ports.
I always thought the 312's were the best of the bunch, too. |
10-07-2019, 03:49 PM | #51 | |
Interestingly, the '57 312 also used Carter AFB and Ford/Autolite 4100 carbs. It was the first year for these carbs too. |
10-07-2019, 08:16 PM | #52 | |
I realized the valve seat (width of the valve) is in line with the wide dimension of the port. Thinking about it even further if you had two situations where you were pouring water over a ledge which way is better? In the case of the conventional vertical port the “fluid” is pinched in the minor width of the port then has to flare out to be able to flow around the valve. In the second case the horizontal port in the Y block has the major intake port dimension in line or parallel to the entire periphery of the intake valve. The “fluid” column is NOT pinched and therefore it’s my opinion that at least theoretically this is a superior configuration. Look at a modern 4 valve engine and tell me what you see looking down the intake port. Answer: generally you’ll see a horizontal and “in line” major port dimension. Maybe just maybe the Y block is the only common 50’s engine that got it right. |
10-08-2019, 07:43 AM | #53 |
like it or not the small block chevy is the best choice . light small ez to install & you can buy a eng much cheaper than any other eng. ps they don,t over heat
10-08-2019, 08:15 AM | #54 |
Plus, used adapters are everywhere. I paid $10 for the last one I bought.
10-08-2019, 09:36 AM | #55 |
I've already said at least twice I'm keeping it all Ford. Suggesting some other brand is just a waste of space. Anyone else checking out this thread to find out the options for doing what I'm trying to do now has to wade through a bunch of non-useful information.
1952 Ford Customline 4Dr New Braunfels, Tx |
10-08-2019, 01:47 PM | #56 |
A friend of mine is installing a Y-block in a 1940 Merc convertible street rod. He is planning to cut a pretty wide diagonal trough in the dash panel (aka firewall) for distributor clearance. Not sure if you would have the same issue with the '52 body.
10-08-2019, 02:07 PM | #57 |
Re top end oiling on the Y blocks. My T bird had no oil to the rockers on one side. The problem was worn cam bearings. New cam bearings were fitted and the oil problem was solved.
Mart. |
10-08-2019, 02:08 PM | #58 |
Might want to check out Tim's page
http://yblockguy.com/ If you want to watch videos https://www.youtube.com/user/mctim64 Sorry this does not help your question on installing a yblock, but some yblock info. . |
10-08-2019, 06:14 PM | #59 | |
The sbc is a terrific engine , but it has its places . Those are in GM products . The best way to ruin a Ford is to put a Chevy engine in it . Works every time ! LOL |
10-08-2019, 06:26 PM | #60 |
Richard makes a good point. I recall in 1961 I had a 40 Ford with a 265 SBC and it ran great with zero problems. Didn't ruin the car at all. Just think of all the old Fords that were "ruined" with 331 Hemis, Olds Rocket 88's and Cadillac engines.
