07-22-2018, 09:50 PM | #1 |
steering box upgrades on a 35 pu with ford parts ?
not mine, asking for a friend who has not registered yet even with my pestering. deal is, he bought a 35 pu project and has no steering box at all, so, my thoughts are since the 35 is still parallel drag link, can it be switched to the later rolling sector cross steer style, for better steering, if so, whats needed, how to, etc. also, that steering shaft must be shorter than a car unit? any ideas?, thanks, skip
07-22-2018, 10:00 PM | #2 |
Re: steering box upgrades on a 35 pu with ford parts ?
1937-1939 Ford steering box is a major improvement. Use the 1935 mount, or modify the later mount. Pickup will have the same box but different steering shaft.
Alan |
07-23-2018, 12:14 AM | #3 |
Cas 3 As far as I know the 35 pick up has the later parallel to the tie rod type steering ,do as Alan says Ted
07-23-2018, 12:20 AM | #4 |
Somewhere I have a nice 38-39 pickup steering frame bracket.
07-23-2018, 02:00 PM | #5 | |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 07-24-2018 at 07:17 AM. |
07-23-2018, 02:21 PM | #6 |
07-23-2018, 07:44 PM | #7 |
thank you all so much. so, its a 37- 41 car plate for the frame, and 37 -39 box?
07-23-2018, 07:55 PM | #8 |
37 to 40 car and pickup frame bracket (and 41 pu) but not 41 car.
07-23-2018, 09:05 PM | #9 |
They are on epay.
https://www.ebay.com/itm/1937-1940-F...sid=m570.l1313 Believe they were also repro'ed for a while. Drake??? You could also get one out of a junk frame. Last edited by Tinker; 07-23-2018 at 09:19 PM. |
07-23-2018, 10:15 PM | #10 |
I think you can buy an adapter to install a Spicer 535 box in the 35. I put one in ny 47 PU with cross steering a few years back, and it works great. I then uo graded it to a 605 PS unit and that works even better.
07-24-2018, 12:16 PM | #11 |
As I recall, the pre 41 pickups are basically a car chassis with a utility body.
I converted my '36 to a '40 steering gear box using a '39-40 frame mount and a '40 pitman arm. #21-A3590-3 015.. My steering column is a '40 with column shift.. The whole affair was basically a bolt in deal... Works almost like power steering compared to the original '36 worm and sector. Several years ago I converted my brothers '36 pickup to hydraulic brakes using a complete '41 front axle assembly, including the front spring, '40 steering gears on a '40 mount with a '40 truck steering column, floor shift.
Bill.... 36 5 win cpe |
09-26-2018, 09:00 AM | #12 |
Ron, or anybody, do you have any pics or more info on these spicer boxes? What do they come from? Box in my 47 is very worn, and I don't need stock setup.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
