11-04-2015, 07:27 PM | #1 |
32 rear Spring or 33/34
Is the 32 through 34 rear spring the same. If not, what is the difference.
Tim |
11-04-2015, 08:04 PM | #2 |
Re: 32 rear Spring or 33/34
As far as I know its close enough to be usable .Ted
11-04-2015, 08:15 PM | #3 |
There were 9,10, and 11 leaf versions. You need to borrow a green bible.
11-05-2015, 12:50 AM | #4 |
They interchange . If you look in a 1934 parts book the number of different ones is amazing . Different leaf counts and length of some leaves . I would assume this was to compensate for the weight differences and carrying capacity .
Also it is more accurate to call them 32-33 and 34 . 32-33 have square leaf ends and 34 has tapered ends . Do a search as this info is already here with pics . |
11-05-2015, 02:43 AM | #5 |
With respect, it's the '34s that have square leaf ends and the '32-'33s which have tapered corners on the ends of the leaves.
In addition, the thickness of the leaves is also a variable between the various types. |
11-05-2015, 04:19 AM | #6 |
The different thickness-length of secondary leaves in a 1934 parts book is amazing and is how different rates were achieved . |
