Old 11-09-2019, 12:57 PM   #1
KITELOOP
Default flathead oil pan
could you please tell me if it does exist a sheet metal that goes on this oil pan!!!!
if yes where I can buy one !!!!
KITELOOP is offline   Reply With Quote
Old 11-09-2019, 01:04 PM   #2
WABOOM
WABOOM's Avatar
Default Re: flathead oil pan
"a sheet metal that goes on it"?
WABOOM is offline   Reply With Quote
Old 11-09-2019, 01:15 PM   #3
Mart
Mart's Avatar
Sorry, Kiteloop, your question does not make sense in English. could you word it differently or show a picture to illustrate?
Mart.
Old 11-09-2019, 01:15 PM   #4
19Fordy
19Fordy's Avatar
Your question cannot be clearly understood. May be a language difference.
Please rephrase, if possible. Post a photo also.
Old 11-09-2019, 01:21 PM   #5
flatheadmurre
flatheadmurre's Avatar
Only sheetmetal that goes on an oilpan i can think of is the clutchcover piece on a 2 piece truck oilpan...or the clean out cover...
Old 11-09-2019, 01:52 PM   #6
Tim Ayers
Or are you talking about an add on windage tray? If so, yes.
Ronnie Roadster added one to my 59AB oil pan. I believe he got it from Canton Racing Products.
Old 11-09-2019, 01:55 PM   #7
40cpe
40cpe's Avatar
delete
Old 11-10-2019, 07:59 AM   #8
Frank Miller
Frank Miller's Avatar
As Tim said I believe he is looking for the windage tray. His first language is obviously not English, which is fine. I knew what he was referring to. Leave one out of a non pressurized Model A or B engine and you;ll have disastrous results. Of course that is not there to keep oil from being sucked up off the pan by the crank.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 11-10-2019, 11:07 AM   #9
rotorwrench
rotorwrench's Avatar
French language doesn't always have direct translations of certain words. Best I can say is using photographs as was mentioned or more descriptive words to add to the mix. Such as metal piece inside pan, or metal piece on rear of pan. We will figure it out from there.
There are different pans for different models and years of Ford automobiles so that is important information as well. French Fords are similar but it could be German, American, or Canadian as well.
Old 11-10-2019, 01:32 PM   #10
DavidG
DavidG's Avatar
I note that he attempted to include a photo. That would be very helpful to those of us limited to one or two languages, neither being the language of the Loire Valley.
Old 11-10-2019, 02:39 PM   #11
deuce lover
deuce lover's Avatar
I sent him a PM and offered to help since I am fluent in French and only a little more than 2 hrs from him.No reply
Old 11-10-2019, 03:25 PM   #12
DavidG
DavidG's Avatar
Sheldon,
Thanks for trying.
Old 11-10-2019, 10:14 PM   #13
Flathead Dave
Flathead Dave's Avatar
Might be talking about the baffels in some of the oil pans.
"Some people are like slinkys. They're not really good for anything but they sure bring a smile to your face when they're pushed down the stairs"....
Flathead Dave is offline   Reply With Quote
Old 11-12-2019, 12:19 PM   #14
Ronnieroadster
Ronnieroadster's Avatar
Maybe the oil pan in question is the type used on the Ford truck engines 8RT type with removable round lower plate for access to the oil pump pickup screen.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 11-13-2019, 07:10 AM   #15
Ziggster
Ronnieroadster
That's what I initially was thinking as well. Hopefully he gets back.
Ziggster is offline   Reply With Quote
