05-09-2019, 08:21 AM | #1 |
Gas splashing out of filler neck while driving
Hi everyone. Stupid question.
1942 ford truck, gas splashes out of the filler neck when driving, pretty much only when I take a left turn or the right side of the truck dips lower than the left. I did add an extra layer of gasket material on the cap which cut the spillage way back, but I still get a little bit coming out. Will a new cap solve this issue? It has an original style non-vented cap, which could even be the original (who knows). I keep the tank no more than half full. Otherwise wondering if anyone makes a device to put into the filler neck like modern cars have with a steel trap door. Thanks in advance. Sent from my iPhone using Tapatalk |
05-09-2019, 09:34 AM | #2 |
Re: Gas splashing out of filler neck while driving
Try a new cap.
05-10-2019, 06:15 PM | #3 |
I had that problem with my 36 and found a plastic piece that had the flipper door in it that is the size of an unleaded spout. I had to whittle the piece down to fit into the neck and bent some heavy stainless wire/rod to make a sort of spring to hold it inside the neck. It has helped a lot and could prolly be sealed a bit better to essentially stop the splashout.
A good sealing cap is also worth getting |
05-10-2019, 06:38 PM | #4 |
I fitted one of those 'trapdoors' out of a jap car into my filler neck...considerably cuts down on the spillage
05-10-2019, 06:49 PM | #5 |
Exactly^
05-11-2019, 02:46 PM | #6 |
Those of you who added the flipper-door, do you know what vehicles they came out of?
'52 F-1, EAB flathead |
05-11-2019, 03:21 PM | #7 |
Dunno...I've done this several times in old Fords, I just go to a wrecking yard and check out various Jap cars until I find one that'll work. Buy the filler neck, take it home, remove the trapdoor- requires minor surgery lol, and fit into the Fords filler neck.
05-11-2019, 05:29 PM | #8 |
Here something I saved from a while back
05-11-2019, 06:53 PM | #9 |
Yes that’s perfect!
05-11-2019, 09:19 PM | #10 |
Thanks, guys!
05-11-2019, 09:30 PM | #11 |
Don't over fill the tank, leave some room esp in the heat when gas expands. Other thing, lots of roads have high crowns, I have run into the gas coming out if the truck sits at to much of an angle, with the filler side on the low side with a full tank.
05-12-2019, 07:00 PM | #12 |
This is from HamtownAl in Virginia .....
05-13-2019, 02:32 PM | #13 |
Hi fellows; Just a note; 40 yrs ago I had a serious Motorcycle crash due to a gas spill on a corner.. looked like water... acted like ice. I quit riding forever, couldn't trust the road. Newc
05-13-2019, 05:35 PM | #14 |
I understand completely. I was a little luckier. About 8 years ago, I got my bike out of winter storage, changed the oil, installed the battery and got it going. One trip around the parking lot, and a little voice in my head said, "Nope, not no more". I sold the bike the next day and haven't looked back.
I hope you suffered no permanent injury. |
05-13-2019, 05:40 PM | #15 |
Interestingly, I’ve been a vintage bike guy since I was 15, so almost 30 years now. This truck is my first real hands on at vintage cars, although I was a factory trained Chevy mechanic for a few years. Being a paramedic was easier so I switched to that and never looked back haha.
05-14-2019, 07:54 AM | #16 |
Tanks makes a fuel cap that has a vent with a ball in it to prevent the gas from coming out. I have one on my 32. It looks like a stock cap. Also has a rubber seal instead of paper.
05-14-2019, 02:35 PM | #17 |
