Old 04-08-2023, 05:11 PM   #1
walls
Default Snyder’s head question
I have what I believe is a 6:1 Snyder’s head
I pulled it off a B engine that I bought last year.
Using that as a frame of reference, I’m assuming the head on my coupe also has a Snyder 6:1 head.
I haven’t driven it since I bought more than a year ago and I’m getting ready to get it running/driving.
What are the odds these same marks without being the same head?
Or do all model A heads have these “dots”?
File Type: jpg BC03209B-D926-4834-B94D-757F7B947622.jpg (58.7 KB, 121 views)
File Type: jpg 8377F409-B38B-43C8-AF8B-2CC55B290478.jpg (48.9 KB, 111 views)
walls is offline   Reply With Quote
Old 04-08-2023, 05:20 PM   #2
walls
Default Re: Snyder’s head question
Now that I’m looking, I see there are stock heads listed on eBay with those dots.
Is there any way to tell whether stock or Snyders head?
Old 04-08-2023, 05:26 PM   #3
Synchro909
Synchro909's Avatar
A photo of the under side showing the combustion chambers would help.
Old 04-08-2023, 06:08 PM   #4
walls
Pic of the combustion chambers
File Type: jpg 115AD9DE-0B16-4761-86AC-B02F7CFCB867.jpg (57.7 KB, 143 views)
Old 04-08-2023, 06:11 PM   #5
walls
Again, now that I’m looking, I’m thinking this is a stock head.
Do you agree?
Old 04-08-2023, 06:58 PM   #6
nkaminar
nkaminar's Avatar
All things head to here: https://www.fordgarage.com/pages/hea...ssionratio.htm
Looks like a Snyders 6.0 head to me. By the way, in my opinion, that is an excellent combustion chamber design. Ask Don at Snyders.
Old 04-08-2023, 07:53 PM   #7
Smokedtires
Smokedtires's Avatar
I have no dimple on my 6.0 Snyder head. Attached pic of combustion chamber.
Smokedtires is offline   Reply With Quote
Old 04-08-2023, 08:27 PM   #8
walls
Looks like mine is a stock head.
I thought it was a Snyder head, but compared to yours, the combustion area goes further into the piston area.
Old 04-08-2023, 08:52 PM   #9
Synchro909
Synchro909's Avatar
And I think the combustion chamber is deeper (that may be an optical illusion) which all means that it is not a particularly high CR head.
Old 04-08-2023, 09:19 PM   #10
Terry Burtz, Calif
That is an original Model A head.
All original heads (and the Burtz head) have those marks.
The 3 marks that you found are where core support wires exited the casting and most were ground off as part of the casting cleanup.
Terry Burtz, Calif is offline   Reply With Quote
Old 04-08-2023, 10:34 PM   #11
31a
The picture you show is a stock head.
31a is offline   Reply With Quote
Old 04-08-2023, 10:38 PM   #12
cas3
I have always thought the snyder head has no marks at all on the top, where as a stock A head will have some casting #'s . True ?
Old 04-08-2023, 11:11 PM   #13
Y-Blockhead
Y-Blockhead's Avatar
Snyder's 5.5 head has two dots as seen in picture. I am not sure about the 6.0.
Old 04-08-2023, 11:46 PM   #14
cas3
Thanks for that info, Y block
Old 04-09-2023, 06:28 AM   #15
walls
Thanks fellas.
I’ve been messing with these cars off and on for 12 years or so and still amazes me how much I don’t know.
Old 04-09-2023, 10:14 AM   #16
ModelA29
ModelA29's Avatar
The problem with heads is everyone wants them to look stock on the outside. The only way to tell is by the combustion chamber. Even then someone may have cast a similar looking chamber (but deeper or shallower) knocking off a part without doing the hard work. You need to figure out the actual volume of the combustion chamber to know for sure.
ModelA29 is offline   Reply With Quote
Old 04-09-2023, 01:51 PM   #17
rich40701
rich40701's Avatar
Just got a Snyder's 6.0 head after flip flopping between 5.5 or 6 and the 6 does not have the dots.
rich40701 is offline   Reply With Quote
Old 04-09-2023, 01:53 PM   #18
rich40701
rich40701's Avatar
The Snyder's 6.0 combustion chamber is pretty rough; would there be any benefit to smoothing it up or would that change the volume too much?
Old 04-09-2023, 06:21 PM   #19
Smokedtires
I've always been in the habit of breaking any sharp edges in the combustion chamber. My fear is, if there is someplace that can start to heat up and glow, it might cause a premature ignition.
Old 04-09-2023, 06:41 PM   #20
Synchro909
Synchro909's Avatar
I agree with that and I don't think there is any point getting too enthusiastic about it. Carbon build-up over time is likely to create more points for pre ignition IMO.
