05-04-2019, 08:13 AM | #1 |
How’s your Shortened pitman arm working?
Just wondering All of you out there that have installed the shortened Pitman arm how much of a difference it makes and how do you like it versus stock?
Isaiah B. 1928 all metal Tudor |
05-04-2019, 08:23 AM | #2 |
Re: How’s your Shortened pitman arm working?
I installed a new one from Snyder’s on my ‘30 Tudor. Steering is much easier. This is the second one I have done. I always use a new one, never a welded one.
Jeff P./MN 1913 Model T Runabout 1926 Model T Sport Touring 1948 Chrysler New Yorker |
05-04-2019, 02:14 PM | #3 |
I just got one from Bert’s and at some spots it’s twice the thickness of the original one. I have not installed it yet.
05-04-2019, 08:25 AM | #4 |
I have a shortened pitman arm on my 30 Tudor that I use for touring. In over 16 K miles, I would not change back to original. I have 19 inch wheels and tires.
It steers easier and I would recommend it for those who have the original steering box. The steering box must be in good condition as well as the other steering components. DO NOT use a shortened pitman arm with the F100 conversion. It makes the steering too slow and imprecise. My opinion, Chris W. |
05-04-2019, 09:34 AM | #5 |
It's like power steering by comparison. However it does put just a little more slop into my sloppy steering and increases the radius of a turn but I recommend them. gary.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
05-04-2019, 09:48 AM | #6 |
They are not expensive so throw one on, quick and easy.
05-04-2019, 02:15 PM | #7 |
I did just pick one up from Bert’s but have not put it on the car yet.
05-04-2019, 09:49 AM | #8 |
I installed a new one from Bratton's, steering is easier, I like it.
05-04-2019, 10:09 AM | #9 |
I have a new one, not welded and it works fine with my rebuilt F100 box. Much better than the 7 tooth I had rebuilt. It still turns lock to lock, so I don't seem to suffer the longer turning radius others speak of. I takes more turns to get there but if moving at all it isd a one finger pull on the steering wheel. Made my own box so I cost just about 200 bucks. I used a 56 Ford pickup unit.
05-04-2019, 11:43 AM | #10 |
I have a stock 2 tooth steering box in my '30 Town Sedan and my steering still goes lock to lock also. I don't seem to suffer the longer turning radius others speak of either??
05-04-2019, 10:16 AM | #11 |
I liked it so much in my 190A that I bought one for my 45B also.
Bob Bidonde |
05-04-2019, 10:57 AM | #12 |
I put a new one about 5+ years ago and it made a difference with no complaints.
05-04-2019, 11:06 AM | #13 |
I use the shortened pitman arms from Wiley Higgins in Cumming Georgia . I am well pleased and use the shortened pitman arm on most of my model A's . When moving , they steer about as easily as power steering .
05-04-2019, 11:06 AM | #14 |
I made one back in 1960 for my widebed, bought one for my tudor with the F-100 box a few years ago and have a AA arm on my speedster. I'm happy with all of them. A shortened arm is even more important if the car has been lowered as everything lines up better.
05-04-2019, 11:19 AM | #15 |
Everyone is saying they make the steering easier but is there not a downside?
At 45 to 55mph would you notice the loss in steering precision?
05-04-2019, 12:09 PM | #16 |
05-04-2019, 02:16 PM | #17 |
Great question.
05-04-2019, 11:50 AM | #18 |
What is the length between the centers on the shortened Pitman Arm's?
Regards Bill |
05-05-2019, 09:20 AM | #19 | |
https://www.brattons.com/new-one-pie...ed-pitman.html
05-05-2019, 09:47 AM | #20 |
I put one on my 29 roadster, and it definitely steers easier. There is a wider turning radius with the seven tooth box, but it's worth it. Between that and the Mitchell transmission, now my wife can drive it.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
