04-03-2018, 08:38 AM | #1 |
Gas filler problem
I have a 37 Tudor. I bought a new tank from Tanks Inc. Perfect fit. I put the filler on, and used the rubber hose between the filler and the tank. When I put in gas. Part of it leaks out. I cant crank on that clamp much more before it breaks. I already broke one. Still leaks. Is there a trick to getting that filler hose to seat?? Thanks
04-03-2018, 08:56 AM | #2 |
Re: Gas filler problem
Look for defects like cracks, deformed metal or hose, foreign objects at sealing surface, is hose seated over bead, clamp not crossing bead, etc. Also a picture is helpful.
04-03-2018, 11:08 AM | #3 |
Could you use a rubber coupler sold in the Home Depot plumbing/sprinkler area?
04-03-2018, 11:20 AM | #4 |
What kind of clamp are you using? Some are much better than others and you can get them tighter without breaking them.
04-03-2018, 11:38 AM | #5 |
Did you use a new rubber hose? They can dry out and get stiff so they dont seat and compress well....... Mark
04-03-2018, 12:10 PM | #6 |
What I had to buy was 36" diesel and gas steel core hack off what you need and sell to Fordbarners or ebay. |
04-03-2018, 01:14 PM | #7 |
I have 2". I will look for the 1 7/8". I bought a flex hose from Drake, and it cracked and leaked after one year sitting. I will check with Tanks Inc. They might also have the hose. As far as the rubber cuppler goes. The gas would melt the rubber. A plumber told me to use two clamps. One on the other side. When you tighten them up. It will tighten it on both sides and not have a kink it it anywhere. Thanks for the help.. Al
04-03-2018, 01:21 PM | #8 | |
https://www.ebay.com/itm/5-Pack-Auth...ZW8dx-&vxp=mtr
04-03-2018, 04:03 PM | #9 |
I found filler neck hose. 1 7/8" $17.00 for 10" it is a flex hose. I will try out those better clamps from ebay.. Thanks.. Al
04-03-2018, 04:05 PM | #10 |
How about heavy duty radiator hose from NAPA?
04-03-2018, 04:57 PM | #11 |
That is the kind of hose clamp I was using. Torqued down on it, and it snapped right off the track. I will try those double wire guys and see if that works.
04-03-2018, 06:24 PM | #12 |
04-03-2018, 06:33 PM | #13 |
I used a gas hose with a radiator clamp. I already know not to use a radiator house. The gas will break down the rubber used in that hose.
