Old 03-17-2019, 04:02 PM   #1
COE Dan
Default Query: How to remove/replace fuel pump valves?
Ford Barn,
I am (attempting to) rebuild a '34 pickup fuel pump. The stock fuel pump internal valves (numbered 9352 on the included diagram) show they are supposed to be held in by a mounting plate (9361) and two screws (26466-S). However, the fuel pump I have, presumably aftermarket, does not have any of these parts and each valve appears to be threaded into the casting (see photo).
Questions:
1) What tool do I use to remove these valves from my pump's casting?
2) Do the rebuild kits available supply threaded replacement valves for my casting or are they similar to the stock pumps?
3) If they are available for my casting, where do I purchase them?
Thank you,
Dan
COE Dan is offline   Reply With Quote
Old 03-17-2019, 04:10 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Query: How to remove/replace fuel pump valves?
Renner's Corner might be able to help you. I'm thinking it's an aftermarket pump. Any markings??
Paul in CT
Old 03-17-2019, 04:12 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
The valves may not be threaded but could be just pressed in.
A manufacturing cost saving design change.
Old 03-17-2019, 08:56 PM   #4
flatjack9
flatjack9's Avatar
Some of these pumps are not rebuildable.
Old 03-17-2019, 08:58 PM   #5
Tinker
Tinker's Avatar
Think CharlieNy does pumps. Not sure myself the availability of check valves, I thought they were not. Maybe Charlie can add.
Old 03-17-2019, 09:02 PM   #6
Charlie ny
IMHO that is a non rebuildable pump. I get a lot them in my shop for rebuild and
discard the top and reuse the base. I install a vintage made in the USA 'back in the
day' top with replaceable valves.
Charlie ny
Old 03-18-2019, 05:55 AM   #7
Terry,OH
Terry,OH's Avatar
Usually the top is marked "AC" for a rebuildable unit.
Old 03-18-2019, 10:07 AM   #8
Charlie ny
Terry's got it.......if you find an AC those are the best, especially quality threads and
nice concentric ferrule seats. However if you uncover a pump with H, BC or B those
are good rebuildables......usually. AC is the primo. I have an ample stock of rebuildable
pump cores plus I build pumps once in a while too.
Charlie ny
Old 03-18-2019, 10:35 AM   #9
revkev6
interesting. back in 2005 when I was putting my roadster back on the road I rebuilt the carbs, fuel pump and older mallory distributor. it had a pumps similar to pictured with press in check valves. the local flathead builder had a supply of check valves. swapped em out and never thought twice about it.
revkev6 is offline   Reply With Quote
Old 03-18-2019, 10:52 AM   #10
Charlie ny
If I built the pump for myself I'd do that...providing of course I found a source for press fit valves. The lions share of my pumps go within and without the contiguous 48 states
however.
Charlie ny
Old 03-19-2019, 07:24 PM   #11
COE Dan
All,
Thanks for info. My pump says "Made in USA" but has no other markings on the outside. There are letter/number combos on the inside (presumably a casting numbers) but no manufacturer marks.
I guess I'll have to get another pump.
Dan
Old 03-20-2019, 10:14 AM   #12
cas3
dont buy a new one, look for an original core
