02-20-2019, 03:55 PM | #1 |
How do i remove the .....
can anyone explain to me how to remove the bushing on the water pump. I have this old pump , took it apart as practice , looks as though the bushing have to be pressed out, I have a press but what special tools are needed ? I searched this site but came up empty .thanks THE HOOCH
02-20-2019, 04:09 PM | #2 |
Re: How do i remove the .....
I would support the casting well and press slowly and straight.
02-20-2019, 07:04 PM | #3 |
socket? tap out?Drive the rear bushing out the rear of the housing!
www.whidbeymodelaclub.com |
02-20-2019, 07:16 PM | #4 |
02-20-2019, 09:02 PM | #5 |
The rear bushing/gland nut is a no brainer. Piece of steel, supporting pipe coupling, and a nice press should push it out the back.
There were some water pumps made which included only a pressed in bronze sleeve in the front. One report I have seen is this was done briefly by Ford as a cost cutting effort, others have said these pumps are "aftermarket." This front bushing if that is what you have can be pressed out from the front. Again a nice piece of steel, probably 3/4 inch is where I would try first, no backer coupling required - there is room between the front bushing and the rear bushing to receive this. Joe K
Shudda kept the horse. |
02-20-2019, 09:12 PM | #6 |
Water Pump tooling
Pipe = notch out to clear grease vein. It is a piece of 1-1/2" pipe about 1-1/2" long. The other pieces are just round bar to fit. I went back and measured them. This is what mine are, but size is not critical as long as it works.(2" dia x 1-1/4"; 5/8" dia x 4-1/4"; 3/4" dia x 1-1/2") You must support the casting around the bushing while you are pressing, or you can break the casting. (Joe K, I meant to post my reply to the original post, but it shows up as a reply to your post.) Last edited by Don Turley; 03-18-2019 at 08:56 PM. Reason: added dimensions |
02-21-2019, 04:02 AM | #7 |
I do it the same as Don. I made a brass driver to press with.
02-21-2019, 07:28 AM | #8 |
Mine is kinda like Don's. 'cept I made my driver by turning down an old rear bushing. Wrks fer me. Once the old bushings are out, clean it throughly, bead blasting is the prefered way , then inspect the housing around where the rear bushing was. Some of them are cracked. Also if the rear bushing is not pressed in purrfeckly square and straight it will crack the housing. Careful and straight. A little grease will help it slide. kenp
02-22-2019, 07:30 AM | #9 |
I've used a large socket and a big "c" clamp. Put the socket on the fan blade end and put the "C" clap over the end of the socket and the threads of the bushing and start turning.
