Old 05-24-2022, 10:32 AM   #1
CA Victoria
CA Victoria's Avatar
Default 1935-36 pickup cowl lacing
The cowl lacing that I bought measures 3/16 thick (same as used around the grill shell). The relief around the cowl varies from + 1/4” on the top to + 3/16 on the side. The deeper area causes the hood to set below the cowl in this area.
Visually it doesn’t look right. Ford must have had a reason or the original lacing was different than the repo product today.
Any thoughts on this discrepancy?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 05-24-2022, 10:52 AM   #2
DavidG
DavidG's Avatar
Default Re: 1935-36 pickup cowl lacing
Whether it matters in your situation, Ford used a hard-core lacing and all that has been available in recent years is very soft and compresses quickly out of shape.
Old 05-25-2022, 11:38 PM   #3
Don Rogers
Don Rogers's Avatar
Here's a drawing of the original lacing material M-17751
Don Rogers is offline   Reply With Quote
Old 05-26-2022, 02:52 PM   #4
CA Victoria
Thank you Don.
Sounds like Ford did not adjust for the difference in lip depth.
The Vintique brand webbing i have is close @ .175-.180 thick x .6 wide
Tim
Downtown, Ca
