Old 04-25-2023, 05:06 PM   #1
Ziggster
Default Question - C59A Oil Pan Gasket (Felpro) Instsllation
I should have probably asked this question before I buttoned up the bottom end, but I guess it is never too late. It was also bothering me a bit ever since I installed the gasket and oil pan. The question is should the gasket be notched around the front rope seal that is installed in the timing cover gasket? I did not notch the gasket and installed it as is, because they didn’t do it in one of the flathead engine books I purchased. Then, I watched a YT video which shows a gasket that is notched to fit around the rope seal. So are both methods acceptable?
File Type: jpg 6798E7A7-EA6D-4BA4-B13A-A41353C0D5D4.jpg (40.1 KB, 71 views)
File Type: jpg D3C6706F-B847-4728-B4AF-0ABED4B93247.jpg (55.9 KB, 73 views)
Ziggster is offline   Reply With Quote
Old 04-25-2023, 05:32 PM   #2
40cpe
40cpe's Avatar
Default Re: Question - C59A Oil Pan Gasket (Felpro) Instsllation
I notched mine because the rope seal sits above the mating surface on the block and the pan a little. A dab of RTV will seal any voids left.
40cpe is online now   Reply With Quote
Old 04-27-2023, 10:07 PM   #3
qmdv
qmdv's Avatar
Maybe two dabs
qmdv is offline   Reply With Quote
Old 04-28-2023, 12:35 AM   #4
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
