Old 08-16-2017, 01:32 PM   #1
modela4shane
Default 12V conversion, COIL POLARITY?
What is the proper coil polarity for a 12 volt conversion? RED wire from switch to + or - side of coil. BLACK pig tail to + or - side of coil. I am using a new coil with internal resister so i wont have a ugly resister on the fire wall. Any thoughts will be greatly appreciated.
modela4shane is offline   Reply With Quote
Old 08-16-2017, 03:18 PM   #2
Art Newland
Art Newland's Avatar
Default Re: 12V conversion, COIL POLARITY?
depends on if you car is (-) or (+) ground.
Art Newland is offline   Reply With Quote
Old 08-16-2017, 03:18 PM   #3
Jim/GA
Jim/GA's Avatar
It's not the voltage of the battery that matters, it's whether you wired that battery positive ground or negative ground.
The red wire coming from the switch needs to match the ground when connected to the coil. The black wire goes on the other side.
This is assuming you wired the car per Henry. When you deviate from Henry's design, you have to figure it out.
Jim Cannon
"Have a Model A day!"
Old 08-16-2017, 03:32 PM   #4
modela4shane
Thanks for the replies, the car is 12V NEGATIVE ground and wired just like Henrys design but with 12 volt negative. If i understand this correctly the red switch wire needs to go to the negative side of the coil and the short black wire goes to the positive side. Correct? Thanks for all the help.
Old 08-16-2017, 04:08 PM   #5
Patrick L.
Patrick L.'s Avatar
The primary lead to the points should be the same polarity as the battery ground.
Old 08-16-2017, 04:46 PM   #6
modela4shane
Thank you to all who replied.
Old 08-16-2017, 05:18 PM   #7
fordcragar
fordcragar's Avatar
I always considered the red wire to be the hot wire in a 12VDC negative ground system. The the negative side of the coil "-" goes to the distributor.
fordcragar is offline   Reply With Quote
Old 08-16-2017, 07:34 PM   #8
Jim/GA
Jim/GA's Avatar
Yea, well, me too! But that's not how Henry considered it, so you would be backwards in this case.
Henry had the red coil wire go to the key switch and then down to the distributor through the armored cable. So the red wire, as you say needs to be connected to the negative coil post on a negative ground vehicle.
Jim Cannon
