05-01-2017, 09:27 AM | #1 |
47 ford vent window crank assy
does anyone have a pic, or an exploded drawing on how the front vent window crank assy works?
Do I need the crank if the spring loaded locking tab works ok? |
05-01-2017, 04:34 PM | #2 |
Re: 47 ford vent window crank assy
I think you would, otherwise the window would just flop around. they sell repair kits for the small regulator.
05-01-2017, 06:26 PM | #3 |
I just replaced mine on my 1941 coupe, got mine from Drake, but here is a link to c$G
https://cgfordparts.com/ufolder/ford...er=11A-7023402 The only problem is two of the rivets are too short to hold well, I used a bolt in mine when I lost one of the rivets. My advice is to take pictures of yours before you take it out, do pictures of both sides. After I drilled out the rivets, I put it together with some 10-24 bolts to check function before I riveted back together. Be sure it lube it good. There is a worm gear on the handle end and the gear in the picture is connected to a shaft on the bottom of the vent window frame. Feel free to pm me for more info. Last edited by corvette8n; 05-01-2017 at 06:32 PM. |
05-02-2017, 07:17 AM | #4 |
My car is a pretty rough project, no interior, and just one vent window without a regulator that's why I'm looking for pics.
05-02-2017, 10:55 AM | #5 |
Is this what you're looking for?
The sign of a good craftsman is how well they cover up their mistakes. |
05-02-2017, 11:32 AM | #6 |
05-02-2017, 11:48 AM | #7 |
That is correct.
