02-27-2012, 03:46 PM | #1 |
Ford V8-60
I am thinking about installing a Ford V8-60 in my Model A PU. Is this practicle or advisable? As I have access to a nice V8-60 engine, it seems it would be lightweight, smoother and 20hp more than the Model A engine. Should I make the hook-up to the existing Model A transmission with an adapter plate, or find a 37 transmission and modify the U-joint/torque tube connection? What's been done before? Any advice would be appreciated.
02-27-2012, 06:44 PM | #2 |
Re: Ford V8-60
I've read where thisa isn't as good a swap as you'd think. Try posting this on the model A forum. Now when I transplanted a pont tempest 4 cyl into my 32, that worked almost as good as the olds I took out.
Paul in CT |
02-27-2012, 06:53 PM | #3 |
Re: Ford V8-60
There was a thread about this topic here on V-8 Ford Barn before but I can't find it.
Most were trying to convince the guy not to do it. One guy said, "Why, are you tired of going fast?" or something like that. T |
02-27-2012, 08:08 PM | #4 |
Re: Ford V8-60
The V8 60 fits a Model A better than the larger V8 for sure but none of them are bolt ins per say. The Model A guys are not the ones to ask about such things. To most of them folks, it's downright blasphemy.
The miget racers of old nearly used up all the good V8-60 motors so there aren't as many as there used to be. Parts are a little harder to scrounge up too. |
02-27-2012, 10:12 PM | #5 |
Re: Ford V8-60
Two suggestions. The little v/8 60 is not endowed with very much lowend torque. With the normal 3.78 ring and pinion in the rear end you will be disappointed with the lack of get up and go. I would recommed and 4.11 ratio to help with that. 2nd. use the "'39" transmission and get the necessary adapters for lthe pedals and wishbone from Specialty Ford Parts of Rosemead, California, phone 626-288-2121. These adapters are very good.
02-28-2012, 01:14 AM | #6 |
Re: Ford V8-60
02-28-2012, 07:42 AM | #7 | |
Re: Ford V8-60
But a standard 85HP trans can be adapted - you just need to hole-saw a hole for the 60 starter bendix and fabricate a cover for it - something like a tuna can or cat food can works. And with that in mind, you can modify any of the adapters for the 85 as well, so you could put a T5 or any other adapter with the same modifications.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech |
02-28-2012, 08:42 AM | #8 |
Re: Ford V8-60
Some other things to consider.
Installing a V8-60 in a Model A PU should produce better results than installing one in a sedan. Ford introduced the V8-60 as a "thrifty" engine but used it in cars that got increasingly heavier. Weigh is a factor of performance. Unless you specifically want a Model A transmission, the various V8 transmissions make driving a little easier with "synchroed" downshifts to 2nd when you need them. V8-60 transmissions varied by year. Early passenger transmissions were smaller than the commercial transmissions, but in 1940 the passenger model was full size like the 85hp and the commercial V8-60. All will "bolt-up" to the Model A torque tube with the right mix of V8 parts, like the clamshell. One advantage, as mentioned, of the larger transmission is the availability pedal, wishbone and e-brake adapters. You lose these when you change from the Model A transmission. Engine mounts and a rear transmission mount must be added. If it's most performance bang for the buck, the Model A can be made to really shine. Otherwise, a V8-60 project can be a slick and beautiful sounding attention getter. Speed parts for the 60 can get mighty expensive.
"Remember that when it comes to intelligence, half of all of us are below average." |
02-28-2012, 01:50 AM | #9 |
Re: Ford V8-60
I ran into a great deal on a very nice V8 60 HP engine and transmission that was being sold by a guy who was just about to drop it into his Model A but apparently 'saw the light' at the last minute and decided not to make this swap. I have also read posts here and articles published elsewhere on why this may not be the best swap to consider. The stories always seem to evolve to the point that you would be far better off with a beefed up A or B engine in that Model A than a little 60 HP engine.
Now on the other hand if you talk to a guy named Richard Willim or read his book 'The Mighty Little V-8 60 HP Powerhouse', he may change your thinking back to going with a little 60 HP in that Model A. IMO, if I were considering swapping a Model A engine with some other type engine it would have to be an 85/100 HP Flathead Ford V-8 engine. Probably not that much more difficult to do, if any, and a whole lot more potential for increased performance as compared to a 60 HP engine. Lots of How To's have been written on what's known the 'AV8'. The most well known of these books is The Bishop & Tardel book on how to built an AV8. The book that probably launched thousands of these AV8 projects. I would suggest carefully reviewing all the pros and cons of this swap before plowing ahead. Good luck!! Last edited by JM 35 Sedan; 02-28-2012 at 01:57 AM. |
02-28-2012, 08:59 AM | #10 |
Re: Ford V8-60
Having driven a 60hp car, and owning a stock A I would say that the A engine wants to be under 3000 rpm, the 60 wants to be over 3000 rpm
02-28-2012, 09:14 AM | #11 |
Re: Ford V8-60
In 1963 when I was 18 I did what you are thinking of doing with a 60 HP V8. I was working in a garage during the summers and after and school both high school and college. My car at the time was a nice 31 Model A Coupe with a worn out engine. One of the mechanics at the garage was a big time fabricator and had just acquired a nice 37 Ford with a smooth running 60 HP engine. He pulled the flathead engine to put a sbc engine in. The 60 HP was mine for the asking. This conversion was a no brainer for me and it did not take long with his help and the assets of the garage to have this engine in my 31 coupe. A very easy install as everything bolted up using the 37 engine and 39 transmission. Glass pack duels and I was a happy guy. The car ran great. I never won any races but it was a good performer for the 2 more years I had the car. Never had any problems with it. The engine was an easy fit and looked like it came from the factory that way. After this long story I would say do the engine swap if you want and I think you will find that it creates a lot of interest when you start it up, especially if your A looks stock. The 60 HP with glass packs had a sound of its own. I was able to get a little bit more speed in each gear using the A rear end. Best regards Dennis
12-05-2013, 08:26 PM | #12 |
Re: Ford V8-60
ok, I am new to the forum and have a question, I have a 1952 Ford Victoria and I need an adapter for 3speed transmission to install a 351W, can I get some info from anyone that can tell me where to get one.
12-05-2013, 08:59 PM | #13 |
Re: Ford V8-60
I'm getting ready to pull the tin sided V8 60 out of my '37. Too bad because the car is original except for '39 brakes but every time I come up the hill to our house I feel like I'm churning butter with all the shifts back and forth between second and third. Tough on the trans when it's one of the early straight tooth gear boxes. Engine is in excellent shape and will be available with the trans after the swap.
Henry made a mistake putting this engine in full size cars. Might work better in stripped down model A. Good luck with it. |
10-09-2014, 08:38 PM | #14 |
Re: Ford V8-60
Might get a better response on the HAMB. The Ford Barn is geared more toward stock and slightly modified cars and stock and modified flatheads. The HAMB is more all out hot rods, although they also have a cut off in the 60s and the 351W would be past that time period. I have nothing personal against the 351Ws as I have two of them, one in a 2005 Focus and one in my 70 Truck, but it is not the focus of this site. Wilcox makes a lot of adapters might try them. One suggestion, why keep the 52 transmission, with a 351W engine I would be looking at a later Ford transmission like a 4-speed or a T5 with an overdrive.
02-28-2012, 10:44 AM | #15 |
Re: Ford V8-60
Hope the v/8 60 is not the "tin side" engine. hard to repair leaks. otherwise a fun little conversion
02-28-2012, 11:36 AM | #16 |
Re: Ford V8-60
I put a '37 60hp in my '52 MGTD a couple years ago, first with an 85hp 3-speed, then a Mustang t-5. I use a reduction-gear starter so no cutting of the bell housing is needed but did have to make an adaptor plate for the t-5. It's been a challenge to keep the body stock, but lots of fun to build, and a blast to drive. The back side is, I've found the 60hp's to be quite pricey, even for just a good rebuildable one (always looking). Marvin
02-28-2012, 12:11 PM | #17 |
Re: Ford V8-60
Hoop is right. An A with a V8-60 actually gets up and goes nicely. I had one in a '31 RPU and it had plenty of power. It is not a very hard installation to do.
02-28-2012, 02:00 PM | #18 |
Re: Ford V8-60
I have been running a V8 60HP in my RPU for about 4 years. Runs great, draws a lot of attention. I have the low rear end and it is pretty quick, but I have model "A" with a HC Wieand head and downdraft carbs that will just plain kick the V8 60Hp to the curb. With that low rear end the V8 60 HP screams at 60 mph. It does help to reduce the weight of the vehicle as much as possible, see the attached picture. The steering column is very close to the exhaust manifold. It was a fun build and a blast to drive. Gary in MN [ATTACH][ATTACH]2007 50's 28 RPU 007.jpg[/ATTACH][/ATTACH]
12-06-2013, 07:48 AM | #19 | |
Re: Ford V8-60
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
09-14-2018, 12:29 PM | #20 | |
Re: Ford V8-60
