09-14-2020, 08:13 PM | #1 |
55 or 56 Ford y block ID ?
Did 56 Ford Y-blocks 272/292 originally have the frost plugs on the front of the heads ?
I thought that was an indicator of a 55 272 y-block. |
09-14-2020, 08:36 PM | #2 |
Re: 55 or 56 Ford y block ID ?
they did for at least the first half of 56.dont know the month the change took place
09-14-2020, 08:58 PM | #3 |
Core plugs in Y-block heads began in '54 and were discontinued sometime in the first part of the '56 model year.
The chart at this link doesn't indicate which heads had them and which didn't, but will help you ID them otherwise... http://ford-y-block.com/cylinderheadchart.htm Photo 2 - a '56 ECZ-C head, without core plugs. I'll assume heads alphabetically earlier would have had them, but I don't know where the break is. Here's a link to an engine block casting number chart because, the same heads were used on different displacement engines... http://ford-y-block.com/Block%20identification.htm . Last edited by dmsfrr; 09-16-2020 at 03:41 PM. |
09-15-2020, 05:08 AM | #4 |
i tried several times to find out where the break is but never did.anyone know
09-15-2020, 07:45 PM | #5 |
My 56 with a build date of 10/21/55, according to the patent plate, has the freeze plugs. It has the original 292.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic |
09-15-2020, 07:50 PM | #6 |
09-15-2020, 08:09 PM | #7 |
09-16-2020, 08:49 AM | #8 | |
No, I have never checked.
09-16-2020, 06:32 AM | #9 |
55Q is on the heads.
09-16-2020, 10:27 AM | #10 |
ted eaton is thinking early in 56.doesnt know if dif and cf heads changed at the same time.you would think with all the 56s out there with original motors it would be easy to narrow it down.
09-16-2020, 11:21 AM | #11 |
Go to ford-y-block.com, scroll down, click on "Technical Info." , and then click on "Cylinder Head Identification."
09-16-2020, 12:45 PM | #12 |
55 Q would be may 17 55.those would be 55 heads.
09-16-2020, 03:49 PM | #13 |
steve fritz, The casting number on the heads should have a three letter prefix with the first two letters being: EC_
from this link... http://ford-y-block.com/cylinderheadchart.htm |
