Old 11-13-2018, 12:24 PM   #1
37 Coupe
37 Coupe's Avatar
Default Main drive gear snap ring question.
I bought a new snap ring spacer
rather than using the old one but I am having a devil of a time getting it on to snap into the groove.Is their some sort of trick or a special tool? I have tried spreading it but I don't want to distort it,I have tried a light press on it thinking that it would spread itself on the starting taper. Ridiculous to spend an hour or two on something like this. I did end of putting the original back no problem but it is kinda loose on the diameter and spins around some.I don't think it would come off especially when the hub or housing bolts on the front of transmission case.Go with the old one?
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 11-13-2018, 11:55 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Main drive gear snap ring question.
A duck bill snap ring pliers should work. I bought mine at Sears. Too bad Sears has closed so many stores, but luckily you should still be able to buy the same Craftsman tool at Lowes or Ace Hardware.
Old 11-14-2018, 12:37 AM   #3
Bill G
Bill G's Avatar
I just did one. Rather we did one. It took a vice, a punch, hammer, screw driver and some cussing, but got it. Held it steady in the vice with a couple rags to hold it still. One person starting one end with a screw driver, and the other "working it" around with a punch. Once you get one end started and can actually keep it in the little channel, your home free. A pair of duck bill snap ring pliers would have helped greatly, but at my friend's shop, we did not have one. A week later, I found my pair.
Bill G is offline   Reply With Quote
Old 11-14-2018, 08:59 AM   #4
37 Coupe
37 Coupe's Avatar
Thanks for both above replies.A buddy is coming over with his extra hands and his Blue Point duck bill set
