Old 11-12-2018, 11:47 AM   #1
fredski53
fredski53's Avatar
Default No Foot Starter
In the latest issue of The Restorer Magazine,there is an advertisement for a push button starter for the Model A. My Victoria has the Ken Davis A/C. The A/C unit blocks the starter button, and makes it difficult to reach the starter button! Has anyone used the No-Foot-Starter? It looks promising! I know it's not what Henry designed, but it would work for me! Thanks, Fred
fredski53 is offline   Reply With Quote
Old 11-12-2018, 12:31 PM   #2
michael a
michael a's Avatar
Default Re: No Foot Starter
There is two ways you can go with this one way is to wire it up like the later model V8 with a solenoid the other way is that starter adapter that attaches to your spark advance lever it's pretty much a bolt on I will look in the Snyder's catalog and give you a parts number
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 11-12-2018, 12:32 PM   #3
Jacksonlll
Jacksonlll's Avatar
Just put in a solenoid then you just push a small button.
Old 11-12-2018, 12:32 PM   #4
michael a
michael a's Avatar
It's called a Sparky start a one one 384 this is at Snyder's I got mine through eBay a little cheaper
Old 11-12-2018, 11:41 PM   #5
fredski53
fredski53's Avatar
Jack, I was thinking about doing what you suggest . I like this because you can use your exsisting cables! And you don't have to drill a hole in your dash.
Old 11-13-2018, 06:26 AM   #6
Jacksonlll
Jacksonlll's Avatar
You do have to modify your starter post to attach a cable to it. Better have a starter guy do it. Good luck.
Old 11-13-2018, 08:06 AM   #7
jhowes
I have the one that attaches to the spark lever and it has worked great for years. I put it in because at age 82 I couldn't push the foot starter button any longer. Jack
jhowes is offline   Reply With Quote
Old 11-13-2018, 10:55 AM   #8
ModelAMike1930
ModelAMike1930's Avatar
I got a tractor solenoid and a push button from ebay. I also got the needed cables there also. I reversed the started switch contact so it was always making contact. It works great.
ModelAMike1930 is offline   Reply With Quote
Old 11-16-2018, 10:26 AM   #9
daveymc29
daveymc29's Avatar
What issue? What page?
daveymc29 is offline   Reply With Quote
Old 11-16-2018, 11:35 AM   #10
Bob C
Here's a link. https://trisisdesign.com/
Old 11-16-2018, 01:30 PM   #11
Davew
Davew's Avatar
How long has this been out? Looks like it would work pretty good.
Davew is offline   Reply With Quote
Old 11-16-2018, 04:08 PM   #12
Bob C
These show up on Epay fairly often.
File Type: jpg $T2eC16d,!)kE9s4,BLkmBQs+W-vv1g~~60_57.jpg (24.8 KB, 110 views)
File Type: jpg $(KGrHqV,!hkFCfi8CFoIBQs+V6P39g~~60_57.jpg (40.9 KB, 119 views)
Old 11-16-2018, 07:29 PM   #13
Jim/GA
Jim/GA's Avatar
Have you considered these:
https://www.snydersantiqueauto.com/up-start
Not a solenoid. But hand operated starter switch.
Jim Cannon
"Have a Model A day!"
Old 11-16-2018, 09:26 PM   #14
wmws
My starter works by pulling on a cable under the dash. That activates a lever on the starter switch to make the contact. It must be something aftermarket but it is the only one I have seen.
wmws is offline   Reply With Quote
Old 11-17-2018, 11:24 AM   #15
Benson
Benson's Avatar
Industrial Model A and B engines in 30's - combine, welders, water pump, sawmill used cables on starters. My Model B Diamond block had one with a governor.
Old 05-14-2019, 10:56 AM   #16
Jason in TX
Jason in TX's Avatar
In 1932, they used a pull cable. You could rig up a cable on your steering column pretty easily with the 1932 switch.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 05-14-2019, 11:02 AM   #17
Jim Brierley
1933-34 starters on their 4-cyl. cars had a remote switch similar to a solenoid, but foot operated. Those starters can be connected with a modern solenoid and either button operated or via a key-switch.
Old 05-14-2019, 11:22 AM   #18
Ruth
Haha, Neither is an A/C... Just sayin'
Old 05-14-2019, 12:45 PM   #19
CarlG
CarlG's Avatar
I am using a key-switch starter that utilizes a solenoid. It was a kit I bought from Merle's Garage in Parker, TX. The kit included all the necessary cables and wiring. Switch fits the regular Model A instrument panel, no holes to drill anywhere.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-14-2019, 02:58 PM   #20
Jason in TX
Interesting! I've been to his shop to do some work on an A and had no idea he was selling those kits. Good to know!
