10-01-2017, 03:34 AM | #1 |
1949 Mercury - Inner Door Handle
My inner door handle on my '49 Mercury Coupe works so-so.
Upon removal of it; I noticed that the odd shaped spring seems to not be doing its job. Anyone know the proper position of that spring? Pictures? Description of what that spring should be doing? Thanks
Matt Allyn 1932 Ford Roadster / 1949 Mercury Coupe / 1949 Harley Davidson "45" / 1957 Cadillac Eldorado Biarritz Convertible / 1957 Lincoln Premiere Convertible / 1959 Lambretta TV175 / 1962 Sunbeam Alpine Convertible / 1962 Chrysler New Yorker Station Wagon / 1962 Chrysler 300H / 1962 Chrysler 300 Sport / 1964 International Travelall / 2015 Tesla Model S |
10-01-2017, 05:27 AM | #2 |
Re: 1949 Mercury - Inner Door Handle
Simple, it keeps the actuator shaft rotated to it's starting position.
10-01-2017, 02:39 PM | #3 |
Appreciate the photos as my driver handle is sloppy compared to the other doors.
1962300 if you find a source for that spring, please post it. I will soon remove my inner door panel for access to the mirror at which time I'd like to replace any springs in the door latch system. Thanks |
10-01-2017, 03:01 PM | #4 |
FWIW the illustration is 1950 Door Lock
10-01-2017, 04:01 PM | #5 | |
'49 uses a rotating round torque rod as opposed to '50-'51 that use a latch pull flat bar.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 10-01-2017 at 04:25 PM. |
10-01-2017, 08:49 PM | #6 |
I could use one though; being that mine is worn out.
10-01-2017, 08:55 PM | #7 |
