12-15-2012, 07:32 PM | #1 |
gear ratio of rear differential
I have a two rear differentials with the numbers 9 34 G2 on one and the second one has 940 stamped in the housing.
Is the one with the 934 stamp a 3.78 gear ratio What does the G2 mean on the first rear mean? Is the one with the 940 a 4.45 gear ratio? If I am totally wrong on this what tis the correct gear ratios? Thanks |
12-15-2012, 08:48 PM | #2 |
Re: gear ratio of rear differential
Ratios are correct, unless the R & P have been changed out. No clue on the G2
12-15-2012, 11:50 PM | #3 |
3.78 takes a 19 tooth speedo gear when used with 6.00 16 tires. It's the universal ratio, good for mountains, flat, city, and highway.
4.44 takes a 23 tooth speedo gear when used with 6.00 16 tires, and is only good for 60 hp engines and parade speeds.
Alan |
12-16-2012, 12:06 AM | #4 |
Thank You!
12-22-2012, 11:51 PM | #5 |
