03-23-2020, 01:01 PM | #1 |
A bit of machining. Re-drilling a flywheel.
This will be part of a separate series just showing machining. In this video I show how I redrilled a total of three flywheels. I redrilled one 9" and two 11" clutch flywheels to take a 10" clutch. I used my rotary table for the first time and found that an improvised counter really paid dividends. By the end of the third one I felt I had a good process going. In a separate video I will go into more detail about the bolt pattern relationships for the Early Ford clutches. Follow along as I virtually teach myself to use the milling machine and rotary table. If you enjoy it please check my other videos and SUBSCRIBE. Mart.
https://youtu.be/JR2uxIaYodo |
03-23-2020, 07:43 PM | #2 |
Re: A bit of machining. Re-drilling a flywheel.
Looks good Mart! I just did mine a couple of months ago. It was a little easier as my new pressure plate bolt pattern was evenly spaced. I just centered the rotary table to the mill. Then I centered the flywheel to the table. Moved it over to the radius required and drilled a hole every 60 deg. Just to be safe I laid the PP on the flywheel and traced the hole locations for a visual reference so I could tell if I was off before I drilled. I even got brave and power tapped the holes. My flywheel was already drilled for three different PP's but there was plenty of room for a few more.
03-23-2020, 09:20 PM | #3 |
I was taught how to lay them out with a pair of dividers and dykem. Need a center pilot the same plane as the clutch surface.
Need to counter bore the hole for the shoulder on the bolt. |
03-24-2020, 09:28 AM | #4 |
What is the acceptable margin of error for pressure plate alignment?
Tim Downtown, Ca |
03-24-2020, 10:01 AM | #5 |
Thank you very much, Mart, for taking the time to make such a great detailed video
so that we all could learn. It's a lot of work to make a really good video that clearly, completely and concisely explains such operations. Wish you were my next door neighbor. You're the best. Jim |
03-24-2020, 10:40 AM | #6 |
03-24-2020, 10:42 AM | #7 |
Yes, I was wondering about having the flywheel and assembly re balanced?
03-24-2020, 10:54 AM | #8 |
another good show mart! i have had one of those clicker/counter things laying around for years, now i know of a use for it
03-24-2020, 11:22 AM | #9 |
Thanks for the interest fellas. I thought it would be of interest to 'barners as it has been discussed in a previous thread. (More than one, maybe). One thing I didn't dwell on was spacing the new holes away from the existing ones. Some techniques mentioned previously didn't do that and I thought it better to space the holes to avoid stress raisers in one area.
Mart. |
