Old 06-23-2019, 10:46 AM   #1
chrs1961815
chrs1961815's Avatar
Default Early 28 Carb?
After restoring one carb I thought I would try another and started to disassemble another one I have that I thought was a double venturi. Somebody had worked on the carb because some things were not right. The bowl has the indented zenith on the front, no threads for the secondary well, and a brass GAV which point to early 28. But there is a vent hole in the lower bowl and some parts that do not belong. Furthermore, I am not sure if the top matches. Can somebody clear this up?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-23-2019, 12:22 PM   #2
F.M.
Default Re: Early 28 Carb?
The top was used from 1928-Sept-1931 on Zenith Carbs. The Bottom was used from 1927-June-1928 on Zenith Carbs..
F.M. is offline   Reply With Quote
Old 06-23-2019, 12:52 PM   #3
Gary Karr
Gary Karr's Avatar
The bowl is actually the second generation Zenith with dowel pins on both front and back. It was used from February through July 1928.
Gary Karr is offline   Reply With Quote
Old 06-23-2019, 01:33 PM   #4
chrs1961815
So the tops and bottoms match and it is a double venturi?
Old 06-23-2019, 05:54 PM   #5
Gary WA
Gary WA's Avatar
Yes
www.whidbeymodelaclub.com
Old 06-23-2019, 09:31 PM   #6
chrs1961815
How are the repro double venturis? A and L sells them and they are usually pretty spot on. I know a guy who rebuilds carbs and he literally has a bucket full of repro venturis that he says don't work.
Old 06-24-2019, 09:52 AM   #7
Gary WA
Gary WA's Avatar
Have some from Berts,Denver excellant quality.www.modelastore.com
Old 06-24-2019, 11:07 AM   #8
redmodelt
redmodelt's Avatar
The double venturi carbs used a different throttle butter fly so don't mix them up.
Old 06-24-2019, 11:08 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
I bought a double venturi from A&L, and it looks great, but I haven't run the carb yet.
