09-22-2016, 03:55 AM | #21 |
Re: Tech: Rear axle bearing sleeve replacement. My efforts.
Nice job.
I was going to do mine on a lathe and was talked out of it due to the accuracy required, so I had the surface precision ground and the sleeves pressed on. The heating and bending of the spring perch is no big deal, you just need to normalise the area by letting it cool down naturally after the bend process, then heat the entire area around where the bend was plus another couple of inches past the bend to cherry red and again let the part cool down naturally. |
09-22-2016, 07:19 AM | #22 | |
My reservation with a ball bearing conversion is that the end float is controlled by the diff. The hub needs to be able to float a little. I couldn't see a way of fitting ball beartings and being able to cope with end float. The roller bearing conversion posted recently has merit, but I thought the roller was a bit smaller than the Ford parts, which may not be a problem, but I had already bought the sleeve, so went with plan A. Thanks, Blacknred, I will give the area a reheat and allow to cool slowly. Mart. |
09-22-2016, 10:10 AM | #23 |
The modern caged needle roller bearings for rotating bearing applications have been around for quite a while and the applications I use them in can take both radial and axial loads pretty well (way lot more load than an old Ford car could put on them). Since the applications are aviation related, the prices for the bearings are way out there and we have to inspect them at 24-month intervals for reliability but they last a long time and are relatively easy to replace. I've had troubles with some that were used in motorcycle drive applications (Harley Davidson) but it was generally due to owners using too large a drive chain that weighed more than the design could handle (they are too small a bearing for that job).
My lathe is only a 6-incher (12-inch throw) so there is no way I could use it to turn an axle bell but luckily there are quite a few machine shops with really big ones around here. Last edited by rotorwrench; 09-22-2016 at 12:36 PM. |
09-22-2016, 12:30 PM | #24 |
Thanks for the great info. and research. I always enjoy your approach to repairing the seemly unrepairable at our small home shops. We can never fail if we don't try. Even if we fail we still learn something .. I always say and I may have said it to you ... we can learn from everyone we meet or talk to. I continue to learn from you.. Theres more than one way to skin a cat... keep up the good work. Thanks pal. Van
