Old 06-25-2020, 07:53 PM   #1
paboot
paboot's Avatar
Default luggage rack
Hello to all.
I was looking for some info about putting a luggage rack on my 31 Victoria
Does it need to have any special brackets for it to fit with the spare on the there?
I have a fellow who is selling one and he says the instructions say it's only for the 2 door sedan and the touring.
Thanks for any help.
Stay safe, PaulB
paboot is offline   Reply With Quote
Old 06-26-2020, 08:09 AM   #2
mfarley
mfarley's Avatar
Default Re: luggage rack
My luggage rack fits both my 28 Coupe and 29 Tudor as they are the same spacing and bolt pattern. However, when the rack is on the 28 Coupe, I could not remove the spare tire as it rode too low and the rack interfered. No issues on the 29 Tudor.
mfarley is offline   Reply With Quote
Old 06-26-2020, 09:13 AM   #3
fuzes45
With spare on 30 Coupe needed to install bracket extensions, to clear tire.
There are brackets that are thicker , so if a heavy load in trunk go for more robust ones.
Bob F
fuzes45 is offline   Reply With Quote
Old 06-26-2020, 09:25 AM   #4
1930artdeco
1930artdeco's Avatar
On my 4 door I opted for the extensions and I still cannot get the spare tire off without removing the rack. One of the guys in the club added about 2" and then it worked. But they need to be really beefed up thickness wise due to the trunk being out so far. I am going to use the 29 version as I think it sits further out normally. I have the aftermarket chrome version right now.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-26-2020, 10:24 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
Mac's has the only luggage rack I have seen listed specifically for the Victoria. https://www.macsautoparts.com/ford_m...-victoria.html You may need the extenders to clear the spare tire. Sorry, the link does not seem to be working. Rack part #28-22144-1, heavy duty extenders part #28-857767-1
I don't know what the deference of the racks are between the different Model A models (Sedan, coupe, Vicky) except for maybe the slant of the back.
To me a trunk looks out of place on a coupe, sort of hangs out in space.
Old 06-26-2020, 10:31 AM   #6
abachman3
abachman3's Avatar
I have the extensions on my Tudor and have no problem with the spare tire, other than the lugnuts are harder to get at.
abachman3 is offline   Reply With Quote
Old 06-26-2020, 11:08 AM   #7
duke36
Here is how it was done on a prior owned SW sedan. The added diag .braces were made from emt conduit to help support the extra oversized trunk weight.
Old 06-26-2020, 12:52 PM   #8
Y-Blockhead
I like the extra bracing. I went another route the rubber mounted the trunk to my spare. I may add the braces, sometimes I have some weight in the trunk.
Old 06-26-2020, 01:04 PM   #9
Bill Cilker
Bill Cilker's Avatar
Paul
With your Victoria's rear mounted spare, you will need the trunk rack extension brackets. See Bratton's #25171.
There are special brackets for a Victoria with side mount spare tires. See picture of my Victoria's original trunk rack mounting bracket.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 06-26-2020, 07:39 PM   #10
paboot
paboot's Avatar
Thank you all for taking the time to answer and help me.
You are a great bunch and this site has to be one of the best.
You have given me a lot of info to work with.
Thanks again,PaulB
Old 06-27-2020, 09:56 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
These are the brackets I have on my 190A:
Bob Bidonde
