10-29-2019, 07:26 PM | #1 |
Steering Wobble
New Spindles, Shocks, Tires (balanced), F-150 Steering, Brakes -- and it just started with this wobble -- so what did I forget, and yes, I rechecked my front wheel bearing - again.
What am I over-looking PLZ -- what a disappointment this is. It's a '31 PicUp Tires about 12 months, rest of work last 4 months Thanks Guys |
10-29-2019, 07:36 PM | #2 |
Re: Steering Wobble
Did you look at front radius ball? I was told this can cause wobble.
10-29-2019, 08:07 PM | #3 |
Re: Steering Wobble
Did you check your toe in and caster. Toe in should be about 1/16 inch and caster I believe about 5 degrees.
10-29-2019, 08:10 PM | #4 |
Re: Steering Wobble
There is something loose. It can be anything between the wheel bearings back thru to the steering box adjustment. Also the toe-in should be 1/16".
10-30-2019, 10:43 AM | #5 |
Re: Steering Wobble
Ditto
10-30-2019, 08:43 AM | #6 |
Re: Steering Wobble
Thanks Guys |
10-30-2019, 09:36 AM | #7 |
Re: Steering Wobble
Long story short. In my case after screwing with everything imaginable check your spring perch nuts. It was a last resort for me. Drivers side took two full turns and pass. side 3/4 of a turn. Problem solved. Patrick L. nailed it.
10-30-2019, 02:58 PM | #8 |
Re: Steering Wobble
Kinda thought you meant king pins.
The tire wear can be camber [ excessive camber is normal for old cars] or improper toe setting. Old cars tend to have a lot of caster too, but, thats not your problem. Look for something loose first, there is a lot to look at. |
10-30-2019, 03:29 PM | #9 |
Re: Steering Wobble
What kind/brand/size tires?? Air pressure?? Tie rod ends good?? Steering box tight to the frame?? Pitman arm tight to the steering box?? Balls on the spindles round?? Toe in??
Paul in CT |
10-30-2019, 04:26 PM | #10 |
Re: Steering Wobble
Fitzpatrick, my roadster also had this problem.
It gots better when I increased the tire pressure to >2.6 bar. But that was not good enough. I've found the real problem: The pan that is sitting on the center ball cup for the front axle triangle (under the car approximately in the middle, don't know the exakt name; see picture) had too much play.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
10-30-2019, 05:37 PM | #11 | |
Re: Steering Wobble
10-30-2019, 06:28 PM | #12 | |
Re: Steering Wobble
I have hip-arthritis -- getting under the PicUp requires two days out from under the Piczup to recover--right now, am checking the spring pearches per a previous post. Found nothing Passengners side today -- Thanks |
11-08-2019, 07:51 AM | #13 |
Re: Steering Wobble
Here's something that would help IF you had the car/truck on jack stands.
https://m.youtube.com/watch?v=qcVVcIj879Y |
10-30-2019, 05:44 PM | #14 |
Re: Steering Wobble
Thanks for this language hint!
11-07-2019, 05:05 PM | #15 |
Re: Steering Wobble
Steering Wobble Update: After contacting Mel Gross about my steering box -- he e-mailed me the adjustment instructions. Our club mechanic and I were able to correct my problem in about ten minutes, fifteen if you include clean-up time. Also didn't realize how loose my steering had become -- there's a lot of confidence driving my PicUp when my steering and brakes are in top shape
11-07-2019, 05:46 PM | #16 | |
Re: Steering Wobble
