11-26-2018, 09:06 PM | #1 |
Cast Iron or Steel Drums?
Undoubtedly an old question, but how does one tell if brake drums are pressed steel or cast iron?
11-26-2018, 09:36 PM | #2 |
Re: Cast Iron or Steel Drums?
There are several manufacturers of cast iron drums and the external appearance of all of them are different but all have one easy to spot feature that distinguishes them from a steel drum. Even as I walk past a car, I can tell whether the drums are steel or cast by looking at the edge of the drum where it is close to the backing plate. The steel ones are stiffened by rolling the edge over so that what you see looks hollow while the cast ones are solid around the outer edge.
Hope I explained that clearly enough!
11-26-2018, 09:55 PM | #3 | |
Bill Williamson
11-26-2018, 11:48 PM | #4 |
Here is a photo of a cast iron drum (left) next to a steel drum (right), the rolled edge on the steel drum is the key element to look for.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
11-27-2018, 03:22 AM | #5 |
At least I got around to putting it in my signature!
11-27-2018, 05:16 AM | #6 |
You and Buster T were missed SAJ in NZ |
11-27-2018, 10:02 AM | #7 |
Good Morning Bill...Great to see you on the site...Feel better every day. Ernie in Arizona
11-27-2018, 10:05 AM | #8 |
Bill, glad to see you back and in you usual form.
David Serrano |
11-27-2018, 11:07 AM | #9 |
You've been missed, Bill. Keep crankin!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
11-27-2018, 03:42 PM | #10 |
Bill, good to see you didn't procrastinate your return.
11-27-2018, 05:51 PM | #11 |
Thanks 160B. The visual is very helpful.
Doug |
11-27-2018, 10:43 PM | #12 |
Randy Gross's cast iron drums are good. cost and quality wise his have done well. Unless a customer brings me drums I generally use his and have done many brake jobs.
Randy's a great guy to work with and I recommend his drums, and if you need I'm sure his other services are top notch. Larry Shepard |
