04-24-2019, 09:40 PM | #1 |
power steering
what is there available for power steering conversions for a 57 fairlane
04-24-2019, 10:45 PM | #2 |
Re: power steering
The original power assist assembly is a complete bolt-on swap. Most of the repro parts suppliers offer replacement power steering pump, pulley, reservoir, cap, belt, hoses, hose mounting bracket and rubber, large bolt that holds the cast-iron pump bracket to the timing cover and power steering idler-arm and bushing kit. You may need to get original power steering pump brackets, control valve assembly, ram cylinder, the add-on crankshaft damper, idler arm bracket and the main steering tie rod. It is also best to use the original power steering sector arm since it is deeper than the standard steering sector arm. I believe you can also re-use your original tie-rod end assemblies.
The repro suppliers also sell the power steering fluid filters, but I buy mine in bulk from a filter supplier much cheaper. You can have an almost completely new power steering setup from the repro parts suppliers, but the cost will add up to $$$. You keep your original steering gearbox as it is |
04-26-2019, 12:55 AM | #3 |
Re: power steering
If you don't care about originality, Borgeson builds a power steering gear box to fit a '52-'64 Ford. There are several places selling R & P kits, but they are a lot of messing around to install
04-26-2019, 07:42 AM | #4 |
Re: power steering
The Borgeson kit is complete down to the mounting brackets for the pump. It's cost is less then sourcing the "original/repop" parts to keep the original steering box.
Either the Borgeson or one of the rack kits will require steering column modifications and as a result the three speed column linkage will not work. Auto linkage will work with slight modifications.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
04-26-2019, 02:18 PM | #5 |
Re: power steering
If I were to do it today, I would check in to an electric power steering unit. Info is available on the HAMB.
04-27-2019, 02:22 PM | #6 |
Re: power steering
04-27-2019, 07:08 PM | #7 |
Re: power steering
Along with the HAMB, there’s a long thread on yblocksforever about electric steering in a 56. Not knowing anything about the 57 steering I don’t know if it’s much help, but it’s an inside read.
http://forums.y-blocksforever.com/Topic112422.aspx I put a Cavalier power rack in my 55 bird. After a lot of screwing around it works. I wouldn’t do it again. |
04-28-2019, 10:23 PM | #8 | |
Re: power steering
I can tell you that a factory '54 Ford P.S. setup will swap with any full size '55, 56, 57 or '58 Ford car if they both came out of Y-block's (there may be an exception to the '57/58 idler arm bracket, but not 100% sure). I couldn't swear to the '59 Ford or Merc. At some point around that time, Fomoco widened the distance between the frame rails. Maybe it wasn't until '60 that they did that. But in doing so, the steering arm-to-idler arm rod of the later cars would have been elongated and may not work. Also the pump mounting brackets are Y-block specific and may not fit with the later FE style engines. And you would also have the difference in the crankshaft damper. |
10-01-2023, 03:02 AM | #9 |
Re: power steering
I know this thread is couple years old but I am struggling with the install of a borgeson box on my 61 fairlane. Everything fits up except for the column connection. I need to modify the column to fit the rag joint. Car is column shift auto.
Does anyone have knowledge on how to modify the column Any help so much appreciated |
10-01-2023, 08:11 AM | #10 |
Re: power steering
Real estate is the problem for the column mounted shifters. The column needs to be shortened. An adaptor to connect the steering shaft to the box is needed. Using a rag joint takes up even more real estate. Borgeson sells an adapter that has an internal vibration dampener that may give enough room the use the column shift arms. Don't know for sure as every one of those units I have installed were in auto cars.
