Old 10-25-2016, 03:13 PM   #1
captndan
captndan's Avatar
Default Anti Rattlers
Anyone have a picture of where the brake anti-Rattlers go on a 31 Tudor? Thanks
captndan is offline   Reply With Quote
Old 10-25-2016, 05:03 PM   #2
dennis lumbert
dennis lumbert's Avatar
Default Re: Anti Rattlers
My Tudor is a 30 with late anti-rattlers
dennis lumbert is offline   Reply With Quote
Old 10-25-2016, 05:08 PM   #3
dennis lumbert
Front anti-rattler
Old 10-25-2016, 06:44 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
They are really called RETURN SPRINGS!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-25-2016, 07:36 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
The front spring mount on the front side of the bracket and push the rod forward.
The rears mount on the rear side of the bracket and push the rods rearward.
Old 10-25-2016, 09:51 PM   #6
Doug in NJ
Doug in NJ's Avatar
In my experience, the wire return springs are much better than the flat ones.
The flat ones seem to lose their springiness.
Either type should be installed so that they are being pressed back against the mounting brackets. In other words, the front ones get mounted on the forward side of the mounting brackets, and the rears on the rear side of the brackets.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
