Old 02-27-2024, 03:35 PM   #1
31ASlant
Default Blowing Starter Safety Fuse Help Please
Any help would be much appreciated.
I’m working on a 30 Tudor
All stock. I have installed a tested generator and
Cutout. When I hook the battery cable up,
The generator cutout immediately closes the points
And since the vehicle isn’t running or ignition on,
It blows the safety fuse.
So basically it’s trying to motor the generator while everything is off.
Now if I attach the cutout without the 2 little screws on the generator body
It all works.
All I can think of is something off the harness from the coil and starter side is
Has power when it touches the batt connection on the cutout top.
31ASlant is offline   Reply With Quote
Old 02-27-2024, 03:55 PM   #2
Bob C
Default Re: Blowing Starter Safety Fuse Help Please
Almost sound like you have the cutout installed backwards.
Old 02-27-2024, 04:09 PM   #3
31ASlant
Here’s a picture. If it helps.
Old 02-27-2024, 04:28 PM   #4
mercman from oz
mercman from oz's Avatar
Here’s a picture. If it helps. 31ASlant
Old 02-27-2024, 04:28 PM   #5
nkaminar
nkaminar's Avatar
Is the cutout for an opposite polarity system? Do you have a positive ground or negative ground?
Old 02-27-2024, 04:44 PM   #6
31ASlant
Positive ground all stock
Old 02-27-2024, 04:45 PM   #7
31ASlant
I’m not sure about the cutout itself. I’m assuming it’s positive ground.
I don’t know if they made them another way
Old 02-27-2024, 04:48 PM   #8
Gary WA
Gary WA's Avatar
It all works.
you need a nylon or non-conducting washer between the cutout and two yellow wires.should not touch cutout.
www.whidbeymodelaclub.com
Old 02-27-2024, 04:49 PM   #9
Gary WA
Gary WA's Avatar
move the two yellow wires on the other side of red washer so not touching the cutout case.put the cover back on
Old 02-27-2024, 04:55 PM   #10
Benson
Benson's Avatar
It all works.
Maybe one of the small screws that mounts the cutout, is TOO long and is shorting one of the field coil wires.
Old 02-27-2024, 05:49 PM   #11
Benson
Benson's Avatar
Here is photo of what Gary WA is referring to>>>
Square part keeps washer in place and prevents shorts to the case cover.
Square part also centers the cover so the screw does not short on cover.
Photo from Berts website: www.modelastore.com
A-10563 GENERATOR CUTOUT INSULATORS- SET OF 2
Old 02-27-2024, 06:16 PM   #12
31ASlant
Ok now I understand. So I’m basically putting 6 volts to the case of the cutout.
Is that why I’m burning fuses?
Thank you
Old 02-27-2024, 07:22 PM   #13
Gary WA
Gary WA's Avatar
Originally Posted by 31aslant View Post
ok now i understand. So i’m basically putting 6 volts to the case of the cutout.
Is that why i’m burning fuses?
Thank you
yes
Old 02-27-2024, 09:16 PM   #14
ndnchf
ndnchf's Avatar
Its the wrong cutout, its backwards and missing the proper insulators. I rebuild generators and refurbish original cutouts. I can provide you with a correct cutout. PM me if interested.
Steve
ndnchf is offline   Reply With Quote
Old 02-27-2024, 09:26 PM   #15
Gary WA
Gary WA's Avatar
Steve
Looks ok to me why is it backwards?
Old 02-28-2024, 04:45 AM   #16
ndnchf
ndnchf's Avatar
The cutout's two feet are always closest to the input side of the cutout and the generator output stud.
Old 02-28-2024, 08:51 AM   #17
Badpuppy
ndnchf is correct. The battery closes the points and connects it to the generator (motor), which blows the fuse.
Question is, where did that generator case come from. Looks like you need to drill and tap new mounting holes. (Careful of the field windings.)
Old 02-28-2024, 09:07 AM   #18
Kurt in NJ
Kurt in NJ's Avatar
That’s a later generator that style just had 2 wires coming out of a grommet instead of the threaded post one for power out, the other is field ground or attached to the oval cutout.
That style reproduction cutout usually has burned up contacts or melted solder where the winding connects.
Turn the cutout around and make a short wire to connect it.
Old 02-28-2024, 09:15 AM   #19
Badpuppy
Ther ya go.
Old 02-28-2024, 10:35 AM   #20
Gary WA
Gary WA's Avatar
Thanks
