07-08-2018, 11:17 AM | #1 |
Cut Off Switch?
This item is mounted on my truck firewall between the battery and the starter. On the inside there is a slotted fitting.
I am wondering if it is a battery cut-off. Thanks, |
07-08-2018, 11:18 AM | #2 | |
Re: Cut Off Switch?
It looks like it would be a cut-off switch - look inside the car on the firewall to see if there is a switch. Test using your headlights or dash light. Sent from my iPhone using Tapatalk |
07-08-2018, 11:36 AM | #3 |
Re: Cut Off Switch?
07-08-2018, 11:37 AM | #4 |
Re: Cut Off Switch?
07-08-2018, 11:39 AM | #5 |
Re: Cut Off Switch?
If it's slotted use a screwdriver to see if it's a switch. May be a key slot though.
07-08-2018, 04:34 PM | #6 | |
Re: Cut Off Switch?
07-08-2018, 04:48 PM | #7 |
Re: Cut Off Switch?
It is hard to tell but the red battery cable looks like it might be a 12 volt cable. If your car is 6 volt it should be replaced with a 6 volt cable.
07-08-2018, 08:50 PM | #8 |
Re: Cut Off Switch?
It was converted to 12 volt at some time in the past.
Thanks to everyone. |
