Old 12-10-2019, 11:04 AM   #1
jhowes
Default differential oil
I rebuild my differential and now it is time to fill it up. The fill is on the down side of the pumpkin and I don't see how to get oil in it. Any ideas? Thanks Jack
jhowes is offline   Reply With Quote
Old 12-10-2019, 11:09 AM   #2
katy
katy's Avatar
Default Re: differential oil
Squeeze bottle.
Old 12-10-2019, 11:18 AM   #3
duke36
Originally Posted by katy View Post
Squeeze bottle.
Yes, or an oil suction gun from Harbor Freight or others
Old 12-10-2019, 12:31 PM   #4
Jacksonlll
Jacksonlll's Avatar
You just want to fill it to that hole that faces the rear of car. Pour it in 'till it starts to run out. That is the full point.
Old 12-10-2019, 01:45 PM   #5
jhowes
Thanks, I thought that I had a screwed up rear end.
Old 12-10-2019, 04:28 PM   #6
Humperhill
While on this subject, what weight oil do you all use in your rear end. I will be flushing and refilling mine this winter.
Humperhill is offline   Reply With Quote
Old 12-10-2019, 08:03 PM   #7
duke36
The closest modern gear lube I've found to the original (almost similar to SAE 250 wt.) is Lubriplate SPO 299 or Meropa 1500 good for yellow metals without a lot of additives. The others on the market seem to flow like modern SAE 140 wt oil. (Lot's of discussions/ opinions in other threads about this subject).
Old 12-11-2019, 02:34 AM   #8
redmodelt
redmodelt's Avatar
600W On a rebuild, I fill mine before I install then top or drain as needed when in the car. Flip it over and use the drain plug to fill.
Old 12-11-2019, 05:22 AM   #9
chap52
chap52's Avatar
The 600 weight from the vendors comes with an additional spouted cap, like a mustard or honey bottle. You can also get a cheap squeeze bottle at the dollar store. Chap
