Old 06-29-2015, 09:08 PM   #1
fredski
fredski's Avatar
Default Starter quickly spins but does not engage.
This happens only occasionally . Should I be concerned?
What is the cause of this and how to fix if I do.
Fredski
fredski is offline   Reply With Quote
Old 06-29-2015, 10:01 PM   #2
160B
160B's Avatar
Default Re: Starter quickly spins but does not engage.
Sounds like the Bendix drive needs a cleaning and a light oiling. See the Ford Service Bulletins page 512, below is the text.
BENDIX DRIVE SERVICE
SUGGESTIONS
Failure of Pinion Gear to Mesh
If stepping on the starter motor merely re-
sults in spinning of the starter motor,
the trouble is caused by failure of the pinion gear
to mesh with the flywheel ring gear. This
condition is usually the result of gummy or
rusted Bendix screw shaft threads. The
remedy is to thoroughly clean the pinion gear
and threaded shaft portion with kerosene,
then carefully dry the parts and reoil with
a very light grade of oil.
Do not use even a
medium oil or any kind of grease inasmuch as
such lubricants congeal in the threads in cold
weather and will again result in failure of the
pinion gear to properly mesh with the fly-
wheel.
Lubricants
Lubrication of the Bendix drive IS not
necessary unless it is noted that the drive is
rusted or exceedingly dry, or unless the drive
has been cleaned with kerosene.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-29-2015, 11:20 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Also be sure the small pin and spring on the pinion weight move freely and have a drop of oil on them.
Old 06-30-2015, 06:17 AM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Very light oil. That baby has to be able to spin in cold weather.
Jacksonlll is offline   Reply With Quote
Old 06-30-2015, 10:11 AM   #5
steve s
steve s's Avatar
When I was in high school, I used to take the starter out and keep it in the house to stay warm over night. Lots of frozen fingers in the morning, working out in the driveway to get us ready to go to school. There was just too much oil flying around to keep that Bendix from getting gummed up.
Steve
steve s is offline   Reply With Quote
Old 06-30-2015, 11:42 AM   #6
Tom Wesenberg
Steve
Way too much work, and cold fingers. What a person could try is to hit the starter quickly with the key off, after you stop the car. Just a quick touch of the starter. Hopefully this would have left the pinion engaged with the flywheel and ready for the cold morning start.
Old 06-30-2015, 12:02 PM   #7
Chris H
Chris H's Avatar
My starter was doing the same thing. I was thinking the Bendix too. After thinking about it a little, I figured that a slow starter might also cause the same thing. Because I was going to disconnect the battery before removing the starter, why not clean the battery terminals first and give it a try. While the terminals looked clean, I cleaned them anyway. It did the trick for me. No more sluggish starter! The Bendix engages just fine now. Just another option. Do the simple things first.
Chris H is offline   Reply With Quote
Old 06-30-2015, 12:10 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
On REALLY cold, frozen mornings, Chief would put a pan of hot coals, from the fireplace, under the engine, about 2 hours before work time.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-30-2015, 12:39 PM   #9
160B
160B's Avatar
Bill W.
And hope there was not a gas leak!!!
Old 06-30-2015, 01:55 PM   #10
BILL WILLIAMSON
Life is FULL of RISKS, HOW DID WE LIVE SOOO LONG???
Bill W.
