01-27-2016, 12:01 AM | #21 |
Re: 6 Volt LED Flasher
That should be Bulb Town
01-27-2016, 03:08 AM | #22 | |
01-27-2016, 06:26 AM | #23 | |
01-27-2016, 07:53 AM | #24 |
This is subject talked about quite often with many different opinions.
The EF33 doesn't work on 6v. The new EF33W might work, its specs claim 6.75-12v. I haven't tried this one. I still use a 535 thermal flasher because its the only one that really works of all the other flashers I've tried with rear LEDs on 6v while adding higher CP bulbs in the front. |
01-23-2020, 08:15 PM | #25 |
Found this 6 volt LED flasher on Amazon. Looks like it's built similar to Tom's homemade flasher using a relay.
AL in NY |
01-23-2020, 09:29 PM | #26 |
This is a US made unit and available through Electro-Tech Products. The price is approx. $125. Their link is http://www.turnswitch.com/Turnsignal.htm |
01-24-2020, 10:06 AM | #27 | |
https://www.ledlight.com/flasher-6-v...e-chassis.aspx This is a very old thread. |
01-24-2020, 11:25 AM | #28 |
Badpuppy, thanks. I found out this is an electronic flasher not a relay flasher and collect polarity is very important.
AL in NY Last edited by AL in NY; 01-24-2020 at 12:13 PM. |
01-24-2020, 06:02 PM | #29 |
It appears there is now a 6v electronic flasher [ from England] that is supposed work with pos ground systems. Can't remember all the info. I still use a thermal flasher with the LEDs.
01-24-2020, 07:16 PM | #30 |
They make them in negative ground too;
I know the voices aren't real but damn they have some good ideas! |
