03-17-2016, 06:00 PM | #1 |
Rear Fenders?
Can not line up the rear fender top bolt hole to the apron on the right side. The left side is good. Look at each fender left side and right, you will see the difference. They line up in the front, but the right fender passes the left about a half inch, now look at the bolt flange, the left has a round edge, the right is straight. The car is a 29 coupe, could one fender be a 28?
03-17-2016, 06:13 PM | #2 |
Re: Rear Fenders?
Can one fender be for a 1928,29 other car besides a Coupe?
03-17-2016, 07:23 PM | #3 |
Re: Rear Fenders?
they are booth 28-29 just made by different manufactures. over the years and with different applications they get tweaked a little.
03-17-2016, 07:43 PM | #4 |
Re: Rear Fenders?
The rounded bolt flange is a '28 to early '29. the straight mounting flange is a 1929. The only reason I can think of that thye don't match is that someone has done work on right fender and didn't get it back to the right shape.
03-17-2016, 07:44 PM | #5 |
Re: Rear Fenders?
Saw a '30 or '31 Coupe, with '28 or '29 fenders & splash shields.---"Did they fit OK"?---"I don't know, it was that way when I bought it". It was a VERY NICE Coupe, NOT Hot Rodded.
Bill W.
03-17-2016, 07:49 PM | #6 |
Re: Rear Fenders?
03-17-2016, 07:57 PM | #7 |
Re: Rear Fenders?
I didn't see any weld marks on the fender when it was sanded on the other side.
03-17-2016, 08:13 PM | #8 |
Re: Rear Fenders?
Okay,..
Were the fenders on this car before?....and fit ? |
03-17-2016, 08:20 PM | #9 |
Re: Rear Fenders?
03-17-2016, 11:42 PM | #10 |
Re: Rear Fenders?
When standing side by side, are they the same height? If the right side is a tad shorter height wise then when it is mounted it may be squeezed and arched more to line up height and length wise to the left side.
03-18-2016, 04:47 AM | #11 | |
Re: Rear Fenders?
Bill "Perfect"
03-18-2016, 06:23 AM | #12 |
Re: Rear Fenders?
The car was previously mostly put together with numerous mistakes, that's why it was stripped to the bone, no more un-detected or detected imperfections permitted. The Dog will not bury this bone.
03-18-2016, 10:11 AM | #13 |
Re: Rear Fenders?
There are a lot of possibilities here.
The change from one style bolt flange to another would not likely have happened all at once, likely there was a transition period where it was mix and match with cars getting either design, or both, at random. There were aftermarket fenders available in the 1930's, and like today's reproductions some were good, some OK, and some ***censored***. Body shops back in the early days were trained to repair rather than replace, and often the "cheap" shops did not get things right and would modify everything to fit to each other though it would not fit to anything original. (The "bad" fender may be shaped to fit a "bad" body.) If there are too many things "not correct" you might consider that car going to someone else to enjoy as a touring class and spending the effort to find a more correct car that you can enjoy restoring to your standards. |
03-18-2016, 11:45 AM | #14 | |
Re: Rear Fenders?
fender when it was OFF THE CAR, that very well could be the problem with the right rear fender. Fix the problem with the fender.. |
03-18-2016, 12:37 PM | #15 |
Re: Rear Fenders?
My 29 tudor had the rounded flange on one side and straight on the other, but both fenders fit fine. So I am guessing that the one that won't fit is messed up somehow. It should be possible to massage it back into shape.
