07-18-2015, 05:17 PM | #1 |
Want to take the coil out of Helmet Coil Cover
Wondering what is the best way?
Coil is dead, so I used the bottom section for a coil adapter, now I'd like to cover it up with the top...but remove the coil. Thanks Last edited by Mike B; 07-18-2015 at 05:44 PM. |
07-18-2015, 05:26 PM | #2 |
Re: Want to take the coil out of Helmet Coil Cover
07-18-2015, 05:43 PM | #3 |
I separated the bottom of the coil, and am using the bottom piece to run a remote coil.
So now I'd like to use the top of it that houses the actual coil, just to cover up the exposed area. |
07-18-2015, 05:45 PM | #4 |
Just drill the top off the three rivets that hold it together, then prize it apart,you have to clean out the old coil and insulation ,
Lawrie |
07-18-2015, 05:46 PM | #5 |
Maybe call Skip Haney in Punta Gorda, Fl and ask him how he does it.
07-18-2015, 05:54 PM | #6 |
07-18-2015, 05:55 PM | #7 |
07-18-2015, 06:32 PM | #8 |
Use a heat gun to soften the tarry substance and 'dig it out'.
07-18-2015, 06:48 PM | #9 |
Maybe low heat in an oven to soften it up (when the wife's not home).
07-18-2015, 06:55 PM | #10 |
Wife was fired long time ago
Thanks Brian for the heat gun idea, will report back in a few! |
07-18-2015, 07:39 PM | #11 |
Success, but heat gun was going slow, so wheeled out the torch
Thanks again! |
07-18-2015, 08:09 PM | #12 |
Me, tending to be the impatient type, also use faster heat, but did not want to suggest that in case....
07-18-2015, 10:35 PM | #13 |
07-18-2015, 10:49 PM | #14 |
Boiling water.........
07-19-2015, 02:37 AM | #15 |
I'd be very careful how you dispose of the innards of old coils, as PCBs were widely used back in the day as dialectric insulators and coolants. Polychlorinated Biphenyl is a known carcinogen and Persistent Organic Pollutant.
Alan |
07-19-2015, 04:15 AM | #16 |
PCB was widely used in cooling oils for transformers/coils/caps.
The tar/asphalt has a chance of being reinforced by asbestos fibres. |
07-19-2015, 06:02 AM | #17 |
Bingo with the PCB, make sure to clean the mess up completely and wear gloves.
08-18-2015, 04:23 PM | #18 |
If you don't swallow it, I think you will be OK?
08-18-2015, 04:39 PM | #19 |
Yeah, we'll send you some in an unmarked envelope.
Alan |
08-18-2015, 05:24 PM | #20 |
No, actually it can be absorbed through your skin.
I recall a reader Digest condensed story years ago as a kid, when an electrician cleaned up a downed transformer. He began having outbursts, burning sensation, etc, that would come and go. It was traced back to getting the substance on his skin (don't recall how much though). No worries, all's gone, tossed it over in the neighbors pool Heck, truck is gone too, on it's way to Sweden...never did get a chance to fit the cap. |
