07-30-2017, 04:37 PM | #1 |
Manifold Gasket - best one?
Hi,
I just put a new Rich Falluca engine in the Town Sedan and am very happy with it. I am having a problem and it is not with the engine. The exhaust manifold gasket is an older, unused, cardboard-ish type. It is gone at the top and back of the manifold. Easy enough to fix but I want to use the best possible gasket this time around. Thoughts? Ted in Calgary |
07-30-2017, 04:57 PM | #2 |
Re: Manifold Gasket - best one?
The two piece copper one worked on for me
07-30-2017, 04:58 PM | #3 |
I use these 1928-mid 30 or A-9448-D, Berts Model A Center [email protected]
www.whidbeymodelaclub.com |
07-30-2017, 05:15 PM | #4 |
I use the single piece sandwich style and tighten from the inside out.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
07-30-2017, 05:25 PM | #5 |
2 piece copper slip in. Worked perfect.
07-30-2017, 06:26 PM | #6 |
I also us the one barkleydave suggested above ^^^ Last edited by Y-Blockhead; 07-30-2017 at 06:28 PM. Reason: Forgot picture... |
07-31-2017, 04:40 AM | #7 |
For the go car the 1 piece fel pro steel clad gasket works well. I surface manifolds to within .0025 and if good and ports align well you should be fine
Larry Shepard |
07-31-2017, 04:41 AM | #8 |
I tried them all and the two piece copper "show" gaskets are the only ones that fit right. They cost a few bucks more but are worth it.
07-31-2017, 09:03 AM | #9 |
These folks make a Model A gasket that sounds great. I have not used it but will the next time I need one. JB
http://catalog.remflex.com/default.asp
Connoisseur of Rust |
07-31-2017, 09:26 AM | #10 |
ive used the late 31 slip in copper ones - work great with a light coating of copper coat on both sides.
your manifolds MUST and absolutely MUST be 100% flat upon the mating surface to the block. If not the best gaskets in the world wont last.
1929 Model AA - Need long splash aprons! |
07-31-2017, 05:03 PM | #11 |
Wow...................remflex recommends 15 ft lbs.............sounds low to me??
Paul in CT |
07-31-2017, 08:48 PM | #12 |
I have always used a one piece gasket made by FELPRO MS2388 S. You can order it at any auto parts store. Hope this helps.
Henry' s 31 |
07-31-2017, 10:13 PM | #13 |
08-01-2017, 01:46 PM | #14 |
I use drop in copper 2 piece made by A&L . Less shrinkage than others. Berts may sell them also.
John |
08-01-2017, 05:15 PM | #15 |
I only use the Copper sandwich type, with a TINY bead of Exhaust Sealant around the port on each side.---DON'T SCREAM, but I torque them to 55 Ft Lbs & several re-tightenings, later.
Bill Noleak
