Old 01-31-2018, 10:40 PM   #1
kiwitony
kiwitony's Avatar
Default Viniger flush
Hi guys i am doing a viniger flush on my 37, i have put 6 litres in and toppedwith water. Is this enough viniger? Also how long should i run around with this in? I tried to do a search but stupid tablet wont give me a keyboard. Thanks in advance . Tony.
kiwitony is offline   Reply With Quote
Old 01-31-2018, 10:51 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Viniger flush
20 minutes at operating temperature should give you all flush possible with vinegar. OK to leave it in for a few days, heat and cool, a few trips, but not for an extended period. flush well with clear water, and use a rust inhibitor water pump lubricant.
Alan
Old 02-01-2018, 12:10 PM   #3
Rustedjunk
Rustedjunk's Avatar
"Rust inhibitor water pump lubricant!?" Which one do you recommend?
Rustedjunk is offline   Reply With Quote
Old 02-01-2018, 12:28 PM   #4
Ball and Chain
Ball and Chain's Avatar
I use water soluble oil, works great. sta lube and a bunch of people make it
Throttle Benders
Est. 1949
Ball and Chain is offline   Reply With Quote
Old 02-01-2018, 01:43 PM   #5
Cool Hand Lurker
Cool Hand Lurker's Avatar
Vinegar might fool you. I put an old rusty but still good hand potato peeler into a glass of diluted vinegar and left it for a week. When I pulled it out there was only a fine thread of the cutting blade left. The vinegar ate it all away in one week!
It sounds like you used undiluted vinegar. If so, I would not leave it in for a week. Drain it after a day and check the results. Maybe even put a rusty piece of steel into a test jar of the vinegar and see how it works on the rust in that time. You sure don't want to risk damage to the engine. That might not be fixable.
Cool Hand Lurker is offline   Reply With Quote
Old 02-01-2018, 04:57 PM   #6
grumppyoldman
grumppyoldman's Avatar
I've used NAPCO oil years ago, with water to lube water pump and fight rust. Now I use a 50/50 mix anti-freeze and water, but down here we don't have that much cold weather. Why do you use water and lube mix, do you drain the radiator in the winter?
grumppyoldman is offline   Reply With Quote
Old 02-01-2018, 05:52 PM   #7
Clem Clement
Clem Clement's Avatar
I use white vinegar for a week. The block developed a leak. 24hours max.
Old 02-01-2018, 05:59 PM   #8
12cliff23
be aware for every 10 degrees you raise the temp. of vinegar it increases its
acidity more than you realize
12cliff23 is offline   Reply With Quote
