Old 11-26-2017, 09:50 PM   #1
Brace Bailey
Brace Bailey's Avatar
Default Saga of the Hood - CCPU
I’ve caught some warm weather the last few weeks - and got my hood painted before winter. I just thought I would post a few pictures of the process.
The Passenger top panel had a crease about 18” long in it. I placed it over the edge of my workbench and gently worked it out. The rest is elbo grease, primer, guide coat, more primer (and a little spot pudy). Hard part is painting each side, then having to wait for the paint or clear to dry before I could flip it and do the other side.
File Type: jpg 2690C4BE-66AF-415F-8EA9-BA0E01C5D917.jpg (47.3 KB, 140 views)
File Type: jpg B1F4F488-65BF-4F25-81B7-F40FADD2753A.jpg (64.3 KB, 147 views)
File Type: jpg E9D34D8D-2069-4D15-808B-D0F9C3416EC9.jpg (64.6 KB, 155 views)
Brace Bailey is offline   Reply With Quote
Old 11-26-2017, 10:00 PM   #2
Brace Bailey
Default Re: Saga of the Hood - CCPU
Part 2
Last picture is my rear window install - took most of today for 22 screws.
Old 11-26-2017, 10:03 PM   #3
Gary WA
Gary WA's Avatar
Coming along Very Nice,Nice work!
www.whidbeymodelaclub.com
Old 11-26-2017, 10:08 PM   #4
Brace Bailey
Shoot, left out a few steps....
File Type: jpg E77990EA-4B5E-4EBE-8270-1D001F8ECBD4.jpg (30.1 KB, 105 views)
File Type: jpg 06AC766D-FC50-4BF3-9530-99D6D8334A7A.jpg (38.6 KB, 96 views)
Old 11-26-2017, 10:50 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
That’s the way it works. A half he job turning into 2 hours••••or more.
Lookin Good!
Old 11-27-2017, 12:03 AM   #6
Larry Jenkins
And.. He had to do a little welding with his new toy.. Nice work, adopted Son..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 11-27-2017, 10:35 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
You COUNTED the window screws?????--The Dog can only count to 16.
Bill Lostcount
"THE ASSISTANT GURU OF STUFF"
Old 11-27-2017, 11:23 PM   #8
Brace Bailey
Yea, I counted them because I managed to loose two of them... How hard is that, they should have been in the cab, right? Then try to find two more that aren’t Phillips head......
Now I’ve discovered that my visor over the windshield has been drilled for tacks in front of the tack strip. More body work to do, after I had a nice coat of paint on it.
Old 11-28-2017, 12:42 PM   #9
Brace Bailey
Sorry - duplicate post
Old 11-28-2017, 03:00 PM   #10
1931 flamingo
1931 flamingo's Avatar
Next time hang your panels.....................
Paul in CT
Old 11-28-2017, 07:57 PM   #11
Larry Jenkins
Paul in CT
As long as you use 4 strings to keep the panels close to level.
Old 11-28-2017, 08:36 PM   #12
Brace Bailey
Default Re: Saga of the Hood - CCPU Now the visor
I don’t have a very good way to hang the items - and from my experience in painting the Visor - it starts moving, and becomes pretty hard to control. Like Pop says, it’s easier to paint it flat.
Started to weld up all the holes... after some major grinding to get to clean
Metal.... I found that trying to weld the holes created bigger holes.
Then the battery in my welding helmet decided it was done doing the darkening/lightning thing, so I was also done with the welding.
Have a nice coat primer drying over the bondo now. Got to buy more Vagabond green. Still have to work on my tailgate, so will need it anyway.
Old 11-28-2017, 10:53 PM   #13
Larry Jenkins
Vagabond Green? Not a Model A color. There were two blue-greens for 1930 CCPUs.
But, like most others say, it's yours, so paint it whatever color you want..
Wouln't the extra holes be covered when the top is installed?
