Old 06-18-2021, 10:30 AM   #1
bigd1101
bigd1101's Avatar
Default Who carries a 1953 Mercury carb rebuild kit?
2100 two barrel Holly. Links please....
Don
bigd1101 is offline   Reply With Quote
Old 06-18-2021, 10:42 AM   #2
scicala
scicala's Avatar
Default Re: Who carries a 1953 Mercury carb rebuild kit?
Do you have a 2100 Holley 3 bolt two barrel or a real '53 Mercury 1901 Holley 4 bolt teapot two barrel carb ? Best price and quality for the 1901 kit I've found is a Daytona kit through seller rburchfield on EBAY.
Sal
scicala is offline   Reply With Quote
Old 06-18-2021, 10:56 AM   #3
jayvee34
jayvee34's Avatar
Macs- Sku 49-49375-1, Alt # 64-49375. For 52 and 53 Mercury full size.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 06-18-2021, 11:11 AM   #4
tubman
tubman's Avatar
It would be informative to know what carb and manifold are on the car. Someone may have replaced them with a Ford unit in the past since he is asking about a 2100. A car of that apparent quality deserves to have an original unit reinstalled.
Old 06-18-2021, 11:39 AM   #5
bigd1101
bigd1101's Avatar
I stand corrected. The carb is bolted to the manifold with 4 bolts. I assume it's this "teapot carb" I've been hearing about. It does look a little like one. Two barrel.
Old 06-18-2021, 11:51 AM   #6
tubman
tubman's Avatar
I believe "scicala" in post 2 is an expert in rebuilding these carbs. I believe that he's just being modest. Unless you are experienced with these, you would do well to have him rebuild your carburetor.
Old 06-18-2021, 11:57 AM   #7
bigd1101
bigd1101's Avatar
I had thought about it, but I don't have the experience. The car is running a lot better since actually "running it" it, but it hesitates a bit when you give it a rev. If it's the accelerator pump, I have a spare but no gaskets to replace any if I have my shop (good guys with old cars) see what's causing the hesitation. If they have to replace the pump they will need some gaskets and why I'm asking where can I get a set? So......?
Don
Old 06-18-2021, 12:18 PM   #8
leon bee
Daytona Carb Parts. Just yesterday I called, said I need a kit for a 53 Hudson Hornet with a Carter WGD. Without any hesitation, he says, "Oh yes, that'll be our 709 kit."
leon bee is offline   Reply With Quote
Old 06-18-2021, 12:26 PM   #9
Merc Cruzer
Merc Cruzer's Avatar
Don,
The stock carb on the 53 Merc was this: the 1901 Holly. Here is the service manual for your files:
http://www.oldcarmanualproject.com/m...l19011952.html
You can get a rebuilt kit at : Kanter Auto Products
https://www.kanter.com/productdetail...Router=Catalog
Daytona is also a good source.
Look up all of the Ford Barn posts on the carb. Allot of good reading, you might want to start with this one:
https://www.fordbarn.com/forum/showt...arb+hesitation
Here is the search list of prior posts: https://www.fordbarn.com/forum/searc...4&pp=25&page=2
Merc Cruzer is offline   Reply With Quote
Old 06-18-2021, 12:57 PM   #10
bigd1101
bigd1101's Avatar
Originally Posted by Merc Cruzer View Post
Don,
I had forgotten about Kantners......thanks!
Old 06-18-2021, 01:07 PM   #11
tubman
tubman's Avatar
Don
I had a friend with a '53 Merc, and he had the same problem. You will be happy to hear that a new accelerator pump fixed the problem.
Old 06-18-2021, 03:09 PM   #12
scicala
scicala's Avatar
I'm here if I can help. It's easy to see if the accel pump is up to snuff on a 1901 teapot Holley two barrel. It should give a squirt out of the two small brass nozzles coming out of the bottom of the bowl with the slightest movement of the throttle, and are aimed at an angle towards the choke plates. If not, that is more than likely the issue as long as you're sure the ignition timing is set correctly and has a strong blue spark, and that the advance is working properly.
Sal
Old 06-18-2021, 04:57 PM   #13
Charlie ny
bigd,
Times 2 re: Sal Scicala is the guy. He'll supply the kit and the know how,
end of story.
Charlie ny
Old 06-18-2021, 06:10 PM   #14
flatford8
flatford8's Avatar
When I called for a kit for Ford carb, the lady said something to the effect of, “I’m on my way to the ladies room, I grab the kit and drop by the mail room. It’ll be on its way today”. That’s service!!!......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 06-18-2021, 07:08 PM   #15
leon bee
When I called, the man himself answered. We talked a while about riding motorcycles around Arkansaw.
Old 06-19-2021, 01:34 PM   #16
RalphG
RalphG's Avatar
I got the kit for my 52 "teapot" through Mike's Carburetor shop". They have a youtube channel with videos on the kits and installation. Now I just have to get busy and do the actual install on mine. I'm still driving it with the hesitation off idle.
RalphG is offline   Reply With Quote
