Old 03-22-2019, 02:57 PM   #1
37 Coupe
37 Coupe's Avatar
Default Coil + or -
I have an old Bosch coil on my Model a '31 that I know works so I planned on reusing it.Today I finally got around to reinstalling the popout switch and new wiring.Problem is on double checking my coil ,wiring schematic and Les Andrews book I notice the coil does not show which post is positive and negative,no + or - nothing. So should I go ahead and buy a coil that is probably going to be China made or this: does it matter which post or terminal I declare positive if I put correct connections on one side and correct on opposite side? Or like I said by a new coil? I also installed the NuRex temperature gauge on the bottom of the gauge panel with the mounting fixture that fits in two bottom holes and gauge is loose in the bracket.What needs to be done tape gauge body to make a fit? Just seems like evry step is an issue nothing ever easy.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 03-22-2019, 03:28 PM   #2
100IH
Default Re: Coil + or -
Even the original coils usually don't have marking. Simple way around is get the ignition polarity indicator tool that everyone sells. Start the engine, look at the light and you have the answer.
100IH is offline   Reply With Quote
Old 03-22-2019, 03:44 PM   #3
denniskliesen
denniskliesen's Avatar
This is what 100IH is talking about. Read page 390 in the Service Bulletins. Ford changed the wires which placed the ammeter in the ignition circuit. Just to not confuse the Nu Rex polarity tester takes the guess work out of it. You can also hold the tip of a pencil between the spark plug wire and the sparkplug to see which side of the pencil the spark occurs.
denniskliesen is offline   Reply With Quote
Old 03-22-2019, 05:40 PM   #4
Railcarmover
Bosch? good coil,if it has a number 15 on one of the tabs thats the hot side.
Railcarmover is offline   Reply With Quote
Old 03-22-2019, 06:35 PM   #5
Badpuppy
How do you define "hot" - positive or negative?
Um, Dennis, pencils are SHOCKINGLY cheaper!
Badpuppy is offline   Reply With Quote
Old 03-22-2019, 06:55 PM   #6
zzlegend
zzlegend's Avatar
It will run either way hooked up. But use the tool,,,,it wont lie.
In my opinion, pencils suck. Dennis has it right. I have 2 of those in my tool boxes'
Just remember,,,,,you can lead a horse to water,,,,,but a pencil must be lead,,,,,,
zzlegend is offline   Reply With Quote
Old 03-22-2019, 07:00 PM   #7
Charlie Stephens
I want to add to your comment: It will run if connected the wrong way, just not as good.
Charlie Stephens
Old 03-22-2019, 07:02 PM   #8
noboD
If it's Bosch it was probably stolen from a VW. And like Railcarmover says 15 goes to the points. With a generator electricity moves from + to - to get to ground which the points are just that.
noboD is offline   Reply With Quote
Old 03-22-2019, 07:04 PM   #9
37 Coupe
37 Coupe's Avatar
It is marked American Bosch.
Old 03-22-2019, 07:09 PM   #10
zzlegend
zzlegend's Avatar
Charlie Stephens
Yes Charlie. I should have stated that. Thanks.
As for those Bosch coils, i am running two of those on my roadsters. Great coils.
Old 03-22-2019, 07:33 PM   #11
daveymc29
daveymc29's Avatar
You can lead a horse to drink but you can't make him water?
daveymc29 is offline   Reply With Quote
Old 03-22-2019, 07:43 PM   #12
zzlegend
zzlegend's Avatar
Originally Posted by daveymc29 View Post
you can lead a horse to drink but you can't make him water?
:d:d:d:d:d:d:d:d
Old 03-22-2019, 09:34 PM   #13
Tom Endy
Tom Endy's Avatar
The pencil trick has been around for ages. High school auto shop teachers loved to demonstrate this to the class, then hand the pencil to the class comedian and have him try it.
Years ago when the tool came on the market I bought one and one day at a club event we checked about 20 cars and found about half were backwards. The owners hadn't noticed the difference.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 03-22-2019, 11:10 PM   #14
Railcarmover
the best inverted 12v coil known to man..see the 15? thats where the hot wire goes,other side goes to the points..
Old 03-23-2019, 04:48 AM   #15
johnbuckley
johnbuckley's Avatar
Tom Endy
Out of interest Tom ,Did they notice any improvement once connected correctly?
johnbuckley is offline   Reply With Quote
Old 03-23-2019, 05:15 AM   #16
Bruce of MN
Bruce of MN's Avatar
Pencil details:
http://www.chicagolandmgclub.com/tec...neral/574.html
Although, if the MG boys are referring to Lucas, caveat emptor!!
Bruce of MN is offline   Reply With Quote
Old 03-23-2019, 09:41 AM   #17
Railcarmover
Originally Posted by Bruce of MN View Post
Pencil details:
Lucas,the Prince of Darkness..had a Triumph Trophy,at night you could light a smoke off the zener diode.On the other hand,German Bosch makes superior components,if youre not into fine point their coil cant be beat,was engineered to run inverted too..
Old 03-23-2019, 10:11 AM   #18
Dick Steinkamp
Dick Steinkamp's Avatar
Posted in error. My bad.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 03-23-2019, 10:13 AM   #19
37 Coupe
37 Coupe's Avatar
I didn't realize that you meant a much newer coil for the #15.This is the American Bosch coil I already had on the firewall and it did run on this. I running new wires and just questioned the previous hookup.
Old 03-23-2019, 10:38 AM   #20
jrelliott
jrelliott's Avatar
Electrons move from - to +. Electricity does not flow only electrons. Voltage is the force that drives the electrons. Amp meters measure the amount of electrons that flow past a point.
jrelliott is offline   Reply With Quote
