06-10-2018, 05:09 AM | #1 |
Widened wheels
I am widening my back wheels. They are 16 inch 5 x 5 1/2 and are 4 inches wide. Rather than cut the rim is there a rim out there that will take my centre.
06-10-2018, 08:52 AM | #2 |
Re: Widened wheels
rather than trying to re-invent the "wheel" by jury rigging a wider wheel/rim onto your wheel hubs, I would suggest you use '58-64 Ford F100 wheels. The F100 wheels are 5 on 5.5 bolt pattern and can be found in widths up to 6.5 widths. The '40-48 passenger car hub caps will fit perfectly on the F100 wheels.
Bill.... 36 5 win cpe |
06-10-2018, 09:17 AM | #3 |
Re: Widened wheels
If you are a member of the H.A.M.B., search there. There are literally dozens of threads with answers. Some of them may not be obvious; I found one that said 16X6.5 rims from a Toyota FJ40 Landcruiser are a perfect fit. There were a lot of others.
06-11-2018, 03:27 AM | #4 |
Re: Widened wheels
Are the 58 to 64 f 100 16 inch
06-11-2018, 05:08 AM | #5 |
Re: Widened wheels
I don't think so.
06-11-2018, 08:18 AM | #6 |
Re: Widened wheels
06-11-2018, 08:28 AM | #7 |
Re: Widened wheels
The '58-66 F100 wheels are generally 5 on 5.5", 15", however, Ford did offer a special 16" option on the F100's.. The F100 wheels '67 through '95/96 are also 5 on 5.5", 15", however, they have external hub cap knobs in lieu of the internal.
I am not positive, but I don't think the EV8F hub caps will fit on a FJ40 wheel.
06-11-2018, 08:33 AM | #8 |
Re: Widened wheels
The outers are called bands and very limited in the inner drop center dia.Check with Wheel Smith in Corona,CA or McLean in Fresno,CA.You might be better off just having wheels made up than trying to make something fit that does not exist.Another issue is what type of hubcaps do you want to use?
06-11-2018, 10:16 AM | #9 |
Re: Widened wheels
When I needed some special 16 inch wheels made and I wanted to keep the original centers so the hub caps fit properly I sent the 16 inch centers to Gary McLean/Rally America and had new outer bands installed. They were perfect with the offset I wanted. It's been a while so I can't remember the cost.
06-14-2018, 05:26 AM | #10 |
Re: Widened wheels
Thanks I had a guy that could widen the wheels but a divorce has put paid to that. He sold his equipment and I can't find anyone else to do it.
06-14-2018, 08:23 AM | #11 |
Re: Widened wheels
Guy named tim in new jersey can do them, i think his business is called wheelsmith. Shipping im sure will be a lot from NZ to Nj
06-14-2018, 03:54 PM | #12 |
Re: Widened wheels
TJ is right. 49-53 F1 pickups had an optional wheel that was 16x5. Mercury had a 16x5 also. 1941 I think. Beware of those who say they can install your
centers in an outer rim that will fit. What will likely happen is they will have to turn the outside diameter of your center down to make it fit. I found this out the hard way. Depending on how wide you want your wheels to be, I would contact Wheelsmith in Ca. They offer 16" wheels in several different widths in a 5 1/2" pattern. www.thewheelsmith.com |
06-14-2018, 04:40 PM | #13 |
Re: Widened wheels
Look up Wheel Vintiques . They have various widths of the wheels you are looking for . I believe Speedway Motors is a dealer . - F F
06-14-2018, 06:33 PM | #14 |
Re: Widened wheels
06-14-2018, 06:43 PM | #15 | |
Re: Widened wheels
06-14-2018, 06:54 PM | #16 |
Re: Widened wheels
Summit Racing is also a dealer for Wheel Vintiques.. Whatever you do don't order wheels from US Wheel. Your hubcaps will not fit.
06-15-2018, 10:07 PM | #17 |
Re: Widened wheels
Elite Wheels, Christchurch, reasonable price!!
06-16-2018, 12:51 AM | #18 |
Re: Widened wheels
I agree Bryn.Excellent job reasonable prices at Elite Wheels 329 0900.Cheers
