10-23-2013, 10:34 PM | #1 |
Repainting numbers on gas gauge
My old eyeballs don't work like they used to. I'd like to repaint the figures on my gas gauge. Would lacquer hold up to a permanent gas bath or what should I use?
10-23-2013, 10:52 PM | #2 |
Re: Repainting numbers on gas gauge
I used Plasticoat Laquer then wipe the face right away to remove all but what lays in the numbers/letters. So far so good. I've used some 10% ethanol, but not in the past 4 years.
10-24-2013, 01:36 AM | #3 |
10-24-2013, 10:48 AM | #4 |
I used Eastwood Extreme Epoxy Chassis Paint, and it looks as good as new after four years. I painted with a small brush, not worrying too much about extra paint. Then after it was dry, I sanded off the excess with #600 wet-or-dry:
http://31ford.dougbraun.com/All_Photos/IMG_2816 Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
10-25-2013, 02:26 PM | #5 |
First, clean the part with thinner. Then purchase Top Flite LustreKote gloss black paint at a hobby shop. The cost is around $9 for a spray can. Spray some in a small cup, then use an artists brush to "flow" it into the numbers. Let it dry overnight, then use a piece of soft wood (pine is good) to buff the surface. It'll remove the excess paint and burnish the chrome plating to where it'll look like new. This same paint is great for painting the carbureter too.
10-25-2013, 03:48 PM | #6 | |
Tom.... |
10-25-2013, 07:23 PM | #7 | |
For the benefit of the others, some of the gauge faces are Chrome or Nickle, (depending on the year/month), applied to the Aluminum. Be careful what you use! |
10-25-2013, 11:53 PM | #8 | |
Doug
